mechanics.... what would you do?
Old 10 Jun 2012, 04:36 pm
Default mechanics.... what would you do?
I have to remove my intake manifold to replace the upper rad hose and install new plugs and wires. Should I replace the seals on the intake or just bolt it back down and forget about it?
Old 10 Jun 2012, 05:13 pm
Default Re: mechanics.... what would you do?
On n/a they are just fine to reuse.
Old 10 Jun 2012, 05:14 pm
check the condition of the seals. if they're in good shape, just reuse them. i did on both of mine.
Old 10 Jun 2012, 05:20 pm
I changed plugs once and also changed the upper manifold twice and always reused the 4 red rubber seals. No problem. Did check them out each time.
Old 10 Jun 2012, 06:39 pm
Thanks guys, I will inspect them carefully, and if they look okay, they stay.
I still have a couple of days before the plugs and wires come in. I hope to trade my upper hose for the correct one tomorrow.
Old 10 Jun 2012, 07:06 pm
Don't forget the correct torque when you put the upper manifold back together. 105 in-lbs on the 5 small bolts.
Old 10 Jun 2012, 07:51 pm
mdfrodolives's Avatar
Remember--that's INCH pounds. Also, it seems like Chrysler says the rubber gaskets can be re-used 10 times.
Tim
Old 10 Jun 2012, 07:57 pm
Yeah, I would never try 105 foot pounds on plastic.... snap.
Thanks for all the info.
Old 11 Jun 2012, 08:42 pm
32, there was a Cruiser on here, a year or so ago, that actually got confused on the issue--costing him a bit more money that he had anticipated.
So I mentioned it ....
Tim
I've taken my PT to three different mechanics and no luck with... PTJeremy Tech & Performance Forum 22 05 Feb 2015 11:48 am
Minneapolis PT mechanics? PeteLover Tech & Performance Forum 7 25 Feb 2012 03:05 pm
I don't trust mechanics..... missjamiemarie Tech & Performance Forum 14 12 Aug 2011 03:12 pm
Getting 2nd opinions from mechanics Greenie General PT Cruiser Discussions 16 03 Feb 2009 12:58 pm
