Dead
Old 11 Jun 2012, 09:48 pm
mikelikestobike's Avatar
Default Dead
Hola,
'03 MT non-turbo - just hit 90K miles. No CEL prior to dying - ***(edit) CEL is on now but we've been testing this and that with this off and that off...(/edit)*** Stopped dead at a red light a couple of nights ago, wouldn't start. Had to tow home. Got (over the phone) opinion of mechanic friend, spent Sunday (and $250) replacing fuel pump. No change.
My mechanic friend and I spent tonight testing ignition coil (seems fine) and signal to camshaft sensor and crankshaft sensor - they seem to be getting signal.
Is there a way to test those items to see if the sensor is good? No CEL is on.
Other thing we are thinking is ECM. Do I just get one on ebay motors that matches my engine and tranny. Does it need to be reflashed?
Any other suggestions? Thanks in advance.
'03 Manual non-turbo in Silver w/ Factory flames.
K & N Drop in, Modded airbox, MSD Superconductor wires, Strut bar, blue dots in taillights. Sold 12/13
Old 11 Jun 2012, 10:02 pm
Default Re: Dead
Timing belt intact?
Old 11 Jun 2012, 10:04 pm
Default Re: Dead
Originally Posted by Busted_PT View Post
Timing belt intact?
Not sure how to check that. I don't have a lot of experience, especially with diagnosing - but can usually figure out how to change a part...
Old 11 Jun 2012, 10:30 pm
Talking Re: Dead
So, the $250 spent on the fuel pump was money wasted. That money would have paid a Chrysler dealer to properly diagnose the problem and maybe even gone a bit towards a repair.
I suppose if enough parts are changed, then the problem may be solved, but that is an expensive way to maintain a vehicle, all in the name of saving money by avoiding those dealer crooks. Go figure.
Old 11 Jun 2012, 10:46 pm
Default Re: Dead
Go to the "how to" sticky that is at the top of the "tech and Performance" section of this site. Go to the how to "replace cam shaft sensor" thread and follow the instructions --- removing two bolts holding the sensor in place, after removing battery negative cable. Now while a "buddy" turns the engine over, check to make sure the end of the camshaft (magnet), that is now exposed because you have removed the sensor, is turning. If it isn't then you need to replace the timing belt.
Jerry
Busted_PT likes this.
Old 11 Jun 2012, 10:51 pm
Exclamation Re: Dead
I agree the bad diagnosis sucks
LOL, yeah the dealer always gets it right!!!
Old 12 Jun 2012, 06:25 am
Default Re: Dead
Yes - you are right, that was $$ wasted. Believe me I'm kicking myself. But thanks for the kick while I'm down, LOL. I never said anything about crooks.
We (my mechanic buddy and I) were pretty confident and the fuel pump, plus it happened on a Saturday night and Sunday - dealerships/ shops closed ... I was trying to just fix it myself and be done with it. Be able to take my kids home.
But we did some testing last night - he believes we aren't getting spark, but he tested the ignition coil and it's fine. He's thinking malfunctioning Cam or Crank sensors... or computer. Can those be tested?
Even if it were the Timing belt - would that cause no spark?
Any ideas? Thanks in advance!
Old 12 Jun 2012, 12:10 pm
Default Re: Dead
if the timing belt is broken, nothing turns, hence no spark. you should be able to take the tb cover off or feel under it to see if the belt is still there.
my bad, the engine will turn over, but that's it.
Old 12 Jun 2012, 12:18 pm
Default Re: Dead
Yes. Broken belt, no spark.
Old 25 Jun 2012, 10:28 pm
Default Re: Dead
So end of the story. Friend and I couldn't really figure it out, but he was leaning towards Timing belt, especially when I told him about your posts...
AAA towed it up the street to a shop, diagnosed it for $45. Timing belt - teeth broke off - might be valve damage?
LUCKILY when I bought the car (I'm second owner bought from dealer) I paid a little extra for a Service contract. Once this shop told me Timing belt - I towed it to a Chrysler dealer and....
They fixed it for a $100 deductible! Told me there was head/ valve damage, but it was all fixed under this service contract! They had it for a week, but that was OK - I was out of town anyway. I lucked out on that.
Thanks for all the suggestions!
dead car klondikeone Tech & Performance Forum 4 09 Nov 2010 02:02 am
Dead PT need help benjibbad General PT Cruiser Discussions 7 26 Mar 2010 03:10 pm
PT Dead - Need Help! silver7 Tech & Performance Forum 14 08 Mar 2010 11:50 am
Pt dead Maineiac General PT Cruiser Discussions 5 21 Jul 2009 10:05 am
Dead, again renichms General PT Cruiser Discussions 6 03 Jul 2003 10:42 pm
