2006 left turn signal out?
Old 21 Jun 2012, 06:33 pm
Samson's Avatar
Question 2006 left turn signal out?
My left turn signal started flashing quick on the dash, and is out when viewed from behind.
Is this a bad turn bulb? Is there a relay to replace, and if so where is it?
Sorry if this sounds dumb
Thank you
Old 21 Jun 2012, 06:40 pm
PT_Panel's Avatar
Send a message via ICQ to PT_Panel
Default Re: 2006 left turn signal out?
Sounds like a bulb to me.
06 PT LT Turbo, Back Doors welded in, Glass out, PTzed
Old 21 Jun 2012, 06:49 pm
Samson's Avatar
Ok thank you, I will pull that
Old 21 Jun 2012, 07:49 pm
wow
X2
Old 21 Jun 2012, 07:58 pm
Samson's Avatar
Originally Posted by wwpptc View Post
wow
X2
Wow??????
Old 21 Jun 2012, 08:24 pm
Samson's Avatar
Hmm not the bulb. Front turn signal works, not rear.
Any suggestions?
Thank you for any help
Old 21 Jun 2012, 08:57 pm
Samson's Avatar
Seems like it might be the backer plate the bulb plugs into
Old 21 Jun 2012, 09:35 pm
Samson's Avatar
Hmm not that either
Old 24 Jun 2012, 02:21 pm
Samson's Avatar
So it's not:
1. Turn signal bulb
2. Bulb socket
3. Multi function switch
4. PCM
5. TIPM (disconnected battery to reset)
Im lost
Old 24 Jul 2012, 11:51 am
Samson's Avatar
Question Re: 2006 left turn signal out?
I checked the harness plug going into the multi function switch, all wires were tight and connected. This was a problem on ford's.
Still looking for a solution.
Thank you
2006 TURN SIGNAL PROBLEM dj78nc General PT Cruiser Discussions 26 24 May 2015 12:52 pm
Windshield Wipers Turn On With Turn Signal or Bump... NewPTCruiserInPA General PT Cruiser Discussions 8 17 Dec 2013 09:10 am
2006 no turn signal or headlight havensole Tech & Performance Forum 13 18 Jun 2011 08:13 pm
2006 - Turn signal/driving lights Tarnishedknight Tech & Performance Forum 10 02 Sep 2010 08:23 am
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
