Is this what I think it is??
Old 23 Jun 2012, 02:37 am
JenneK's Avatar
Default Is this what I think it is??
Removed radiator cap and had wife crank cold engine of my 01 w/91k. It pushed coolant out of the opening.
Car w/n start...most of the time. When it does it runs fine but overheats quickly.
I recently flushed the coolant and noticed black flecks of something in the water when I was flushing the block w/hose. Wondering if previous owner tried fix something with some of the "fix head gasket leaks" in a bottle.
Car has new radiator, thermostat and cap. No coolant leaks. No coolant in oil.
I suspect a bad head gasket. What say you?
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 23 Jun 2012, 06:47 am
Default Re: Is this what I think it is??
Ken,
Don't worry about pushing water out of the hole where the radiator cap is, all cars will do that.
Can't say about the black specks but overheating is a major problem on the PT and most of the time it's because of the radiator fan. Other questions: Are you loosing any coolant, any leaks? Whoops, you already said NO to that one. When filling with coolant, are you getting all the air out of the system? Any white smoke out of the tailpipe?
Back to the fan. On a cool morning. Open the hood and use a flashlight to look for your radiator fan. Hard to see without a light. Now start the engine and turn on the A/C. Go to the front and (be careful) look for the fan, it should be running (some say high speed, some say low), either way it should be moving. Whenever the A/C is ON, the fan should be ON. If not, like many others, the fan motor is partially burn out and needs to be replaced.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 23 Jun 2012, 07:03 am
I rarely disagree w/Crewzin - but I do think Head gasket - I do not get coolant pushing out of radiator when I take off cap and start it cold. Can't hurt to check fan first, but doesn't sound good....
Old 23 Jun 2012, 07:53 am
If cams were stuck the motor wouldn't turn over. If you don't have cam rock, witch is when cam is teatering end to end when cam is in the head. Then you could mill the head. Has the magnet for sensor been looked at? Should test fire before putting cover back on.
Old 23 Jun 2012, 08:02 am
I think you're replying to another thread - where mechanics said cams were stuck after timing belt broke
Old 23 Jun 2012, 10:06 am
I hate to say it, but it does sound like a blown head gasket. If it's pushing coolant out when cold. If revving the engine also blows the coolant out, then I'd say not good. One way to be sure it to get a combustion gas tester for the radiator. I'm not sure if they are sold in auto parts stores, but I got one online and it immediately told me that there were combustion gasses in the coolant hoses. After replacing the HG, the test came back negative, so I know it worked, and I no longer had overheating issues, bubbling coolant, etc...
Although, of course, I had to replace the radiator fan too, so definitely look at that.
Old 23 Jun 2012, 10:38 am
Yep you'r right. Must have had a brain fart!
