Radiator fan not working
Old 23 Jun 2012, 05:31 pm
Default Radiator fan not working
My fan doesn't come at all. I ran a jumper to high & low sides of connector' and they both work. replaced both relays, and the sensor under/ at the rad cap. Nope, doenst work.Tryed the code readout and got p 1684 , 0601 , 1490 any suggestions, help? Looked in the library- 0601 said control module fault, does this mean it needs replced? When I said both sides were working, I meant the fan high and low turn on and run w/ jumper from battery. The fan works, but somehow isn't getting orders to work from the system, or somthin like that
Old 24 Jun 2012, 08:22 am
Default Re: Radiator fan not working
Some information to read:
P0601 error replacement parts
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 24 Jun 2012, 08:25 am
cruserdad1976's Avatar
get a new on and be done with it lots of folks repace relays nd most of the time that still dont fix it a new fan is $89 on ebay
Old 24 Jun 2012, 03:22 pm
Attach a volt meter to the pins of the wiring connector that attaches to the fan connector. Check to see if it's registering a voltage when you turn the A/C on. It would be on one of the outside pins, and the middle pin is ground. Not sure which of the outside pins would show the voltage, but check both. Also, when your vehicle gets up to temp, the other pin should show voltage.
If they do, then your fan is probably broken (although you said it comes on with hard-wiring, so that would be weird). If you're not getting any voltage, then the problem lies somewhere else. BUt I'd start there just to make sure, before you start replacing anything.
Old 24 Jun 2012, 04:33 pm
Ray_Dockrey's Avatar
My daughters 2006 did the same thing. We had a fan failure but when we pulled the fan and ran direct voltage to it it worked just fine but would spin at the same speed no matter which pin you hooked too. We even hooked it back up to the car and it worked okay. We figure maybe we knocked the brush loose when we removed it. We replaced the fan anyway and no more issues. I took The old fan apart and one of the brushes was completely wore down.
Old 01 Jul 2012, 04:15 pm
Have you managed to get a fix for this yet? Mine does the same thing, works fine when you hard wire the fan, and can see the relays switching when they reach temp but for some strange reason the fan isn't starting..
Would be interesting to see if you managed to find the problem so I can try it on mine too..
Cheers,
John.
2001 Aquamarine LE
Old 01 Jul 2012, 04:49 pm
I am also fighting a similar issue with a 03 pt. Had fan replaced and worked fine for about two weeks. Now it's out again. Taking it back because I am not sure if the fan motor quit again which is under a 30 day warranty or will they tell me something else is wrong.
Mart
Old 01 Jul 2012, 08:56 pm
mdfrodolives's Avatar
Mart, was if a Chrysler fan? or aftermarket?
I'm thinking you got a generic E-bay (some of which work okay--and some not so much).
Tim
Old 01 Jul 2012, 11:29 pm
I was from a long time auto repair place that is reputable and has been in business for 30 years that I know off. The fan assembly was like 300 dollars approx.
Radiator low speed not working Scott_hrpr Tech & Performance Forum 3 10 May 2012 10:57 pm
01 pt cruiser radiator fan not working HELP salteedogg Tech & Performance Forum 14 18 Mar 2012 03:47 pm
Radiator fan not working! HELP Zerotolerancecustoms General PT Cruiser Discussions 2 20 Feb 2012 09:19 am
HELP!!!: radiator fan not working... him72787 Tech & Performance Forum 10 17 Jun 2011 09:21 pm
Ok radiator fan is 5 months old and half working! invidious Tech & Performance Forum 4 20 Apr 2011 04:02 pm
