Erratic gauge and dash lights activity
Old 25 Jun 2012, 12:50 pm
Default Erratic gauge and dash lights activity
Hello, I am having an issue. I'm driving and all of a sudden all dash lights go on, all gauges drop and then goes back to normal. There is no rhyme or reason as to when this happens. Doing 60-70 on expressway or 40 on regular road. Every once in a while when this happens the engine bucks. Can go a week or more with out this happening or can happen 10 times in a 25 mile trip home from work. I have a 2006 conv with 96,000 miles.
Please help
Thanks,
Joe
Old 25 Jun 2012, 01:33 pm
Default Re: Erratic gauge and dash lights activity
sounds to me like a weak battery.
Old 25 Jun 2012, 01:41 pm
Why would a weak bettery cause this?? The battery will be 3 years old in 2 weeks. This has been happening since last fall or winter. But went away for months. Now it's back.
Old 25 Jun 2012, 02:13 pm
Joe,
The battery (when it starts to weaken) does create havoc with the dials, gauges, radio and all thing electrical. Can't hurt to have it checked out. You came here for help and we're telling you what we know about the PT from others having the same trouble.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 25 Jun 2012, 02:26 pm
I appreciate the help. I really do. I will have the battery checked today. Also looking for any other thoughts.
Thank you
Old 25 Jun 2012, 03:08 pm
OK, other things. Are yo getting any faults stored on the computer which happens if the engine light comes on?
You can pull your own fault codes by using the instructions below:
How to retrieve fault codes.
Also when you go to have the battery checked out, look at the battery terminals, Check them to see if they are good and tight and look for any corrosion that would stop full battery power from getting to where it has to go.
Old 25 Jun 2012, 04:21 pm
I did forget to mention that there was a lot of corrosion on the battery terminals and I cleaned it last week. It was good for a day then started to happen again.
Old 25 Jun 2012, 05:56 pm
mdfrodolives's Avatar
Destroyer, when this happened to me, it was corrosion on the battery terminals and a weak battery. The corrosion was so bad, I needed a new wiring harness (positive side).
Make sure if you replace the battery, you clean the battery terminals, spotlessly. Pay special attention to the interior of the clamps. Also, look to see if corrosion has gone under the insulation (near the positive clamp). Also, after snugging on the clamps, spray with CRC Battery Protectant, so you won't have corrosion problems again for a long while.
Tim
Old 26 Jun 2012, 03:31 pm
I replaced the electrical part of the ignition switch a year ago. Problem stopped.
BOOST GAUGE TUTORIAL (Up dash mount) niel General Turbo Discussions 18 08 May 2017 01:01 am
Blinking indicator lights and erratic gauges - 2006 PT Cruis Convertible ptowner5 Tech & Performance Forum 8 19 Sep 2016 03:37 pm
no dash lights or head lights suescruiser Welcome New PT Cruiser Members 0 14 Feb 2012 10:44 pm
Dash lights and tail lights out ab1 Tech & Performance Forum 2 01 Feb 2012 04:34 pm
dash gauge lights fritz01 General PT Cruiser Discussions 4 04 Sep 2009 08:30 pm
