I just found out about this site and as I am a new pt owner I thought I would post with a big problem. I have a 2002 pt limited and the tranny will not shift. I put my scan tool on it and the code comes up as p0700 which is a dtc with the tranny controller. It is here where I am at a loss. How do I find out what part of the tranny is bad?
I believe from the research I have done that the tranny is in a " limp home" mode that leaves the car in 2nd gear. After that bit of info, I am stuck in the dark. Help!! ![]() |
![]() Quote:
![]() Quote:
What VNT said! Jerry |
The car has 117,000 miles and I have no service history of the vehicle. ( bought it cheap at an auction. Is there a special scan tool needed to further diagnose the problem? I take it that is what the dealership will use?
Yes, the dealer has tools called DRB and StarScan. A 2002 will use the DRB and it will communicate with the car systems to determine the exact fault and repair needed. You cannot do that with a standard universal scanner.
-Chris 2010 PT Cruiser Classic, Deep Water Blue ![]() |
If you have not already tried it, I'd pull the neg battery cable and stand on the brake pedal for 5 min or so to discharge all residual? memory.
Then reconnect to see if the code reappears. I threw this code a few years ago at the track. Dried the tires off after going through the water box and BAM P0700 ![]() ![]() Luckily, I haven't seen that same code or been back to the track since ![]()
..................................... ![]() '03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned ![]() 1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07 ![]() FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer |
Okay, I have an update. I tried a better scanner tonight from a friend and pulled an additional code. P0605 Internal control rom module malfunction.
I have tried several searches on this website and others and am getting conflicting info from them. Any suggestions what to do from here? |
Both P0700 and P0605 are TCM faults. More importantly P0605 is an internal fault within the TCM, for which Chrysler recommends replacing the TCM.
Thread Tools | |
Display Modes | |
New Member With A Strange Problem | Elmo | Tech & Performance Forum | 2 | 08 Jan 2012 10:56 am |
Baffling Tranny Problem | 07PCH | Tech & Performance Forum | 7 | 02 Aug 2011 04:52 pm |
New member,and new problem | tpres | General PT Cruiser Discussions | 2 | 25 May 2010 06:00 pm |
2008 brake or tranny problem | aenima45 | Tech & Performance Forum | 1 | 06 Jan 2009 07:52 pm |
Dealership & Tranny Cooler problem | bimmerchuck | General PT Cruiser Discussions | 4 | 06 Feb 2006 11:13 am |
