02 Cruiser, won't crank
Old 26 Jun 2012, 08:58 pm
Default 02 Cruiser, won't crank
The car acts like the neutrel switch is not letting it crank. Everything works except the cranking and no fuel to injectors. Pump runs, and gets gas to them. It hold a hole in line to fuel rail and was pushing gas out. Replaced and still no run. You can jump across starter and shoot gas into intake and it will run abit. This is a friends car and started when he had to replace the keyswitch as it locked up. Now it will not crank, as stated acts like the neutrel switch is thinkin car is in gear. HELP!!
Old 26 Jun 2012, 09:09 pm
Default Re: 02 Cruiser, won't crank
The key has a chip in it If the chip is not recognized or the wrong key is used it wont start. The key switch is your problem. What is the whole story on the switch you put in.
Old 26 Jun 2012, 11:17 pm
Going by what he told me, the keyswitch locked up. He changed it out and had to reset the tumblers. Tried this 3 times and the switches kept locking up.This was using old key in new switch. Then current switch is in car with a new key, and they told him to just have original key in area of column/switch.
Is this somewhat correct? I have never dealt with something as done here. I just know it will turn but no crank. Everything works, pump even runs on key on, just not no fuel to injectors. And no crank. Thanks for any help you can be!!!
Where I said it will turn but no crank, I meant the key will turn, it does not crank/turn the motor over.
Old 27 Jun 2012, 04:25 am
You need key programed to pt. Unless someone has another way.
Old 27 Jun 2012, 04:32 am
What does he need to do go get it programed?
Old 27 Jun 2012, 09:14 pm
Call the dealer, but I would say you will have to take car and key to them. First I would search here for the threads on the switch replacement. Might be something there that might help. Something they did different.
OBX UNDERDRIVE CRANK PULLEY 03-06 PT CRUISER 2.4L TURBO ROCKETMAN8060 Tech & Performance Forum 12 16 Jul 2011 12:38 pm
2001 cruiser limited will not crank at all :( rrcruiser General PT Cruiser Discussions 3 09 Sep 2010 06:26 pm
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
02 pt cruiser won't crank over. vanhalen7174 Tech & Performance Forum 2 04 Apr 2010 12:06 pm
02 pt died and won't crank over ronwins3 Tech & Performance Forum 16 23 Dec 2009 06:25 am
