My PT started off by idling very rough when I had the A/C on. After some searching and reading some threads on the forum, I decided to clean the IAC valve. After cleaning it, getting the exhaust manifold and everything back together, it idles much better but it now idles kind of low at just under 500 RPMs. Could it be that the IAC valve needs to be replaced?
Does this only happen when your AC is on? If so, your radiator fan could be broken. Check to see that it comes on when you turn the AC on. If it doesn't, then the brushes on the motor wore out and it needs to be replaced.
As far as the IAC, I'll let someone else comment on that, I've never had a problem with that on my PT, so I don't know. |
Besides the IAC attached to the throttle body there's also the throttle position sensor (which can't be cleaned, and also built up carbon inside the throttle body. Can't speak on the IAC as I've n3ever had it apart but the spring could be shot that makes it work.
![]() ![]() ![]() ![]() ![]() 2000 PT. Original Owner, 123,000 miles MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage. Cruiser Of The Month (COTM) May, 2015. Visit My Home Page www.CREWZIN.com I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you. |
If you didn't adjust the pintle when cleaning the IAC, then re-remove it and adjust following the instructions in the pic below. After reassembling, it will "wander" for a few minutes after first starting it up. During that process it and the PCM are getting reacquainted and will find their own sweet spot in a very short time.
![]() ![]() PLEASE click below Jerry
Thread Tools | |
Display Modes | |
Idling Hesitation | Ken Swenson | Tech & Performance Forum | 17 | 25 Feb 2013 04:50 pm |
almost dies while idling | chaoscow | Tech & Performance Forum | 19 | 16 Feb 2013 02:48 pm |
Problem with Idling? | 03TibbyGuy | Tech & Performance Forum | 6 | 19 Oct 2010 11:51 am |
Idling issues | FatalFurr | Tech & Performance Forum | 4 | 06 Apr 2010 09:17 am |
A/C noise when idling | 2002ptcruiserwoody723 | Tech & Performance Forum | 3 | 05 Nov 2009 02:16 pm |
