"Popping" Noise when backing up
Old 30 Jun 2012, 11:50 pm
Default "Popping" Noise when backing up
My '03 Touring Edition makes a loud popping noise when I back the car up. This only happens when it's been sitting for a while (like when I back out of the driveway), or if I've been driving it for a while, then I need to go into reverse. If I'm backing up, then stop, then back up again, it doesn't happen. It's only that initial time I back up.
The noise seems to come from the frond end. In the past year or so I've changed the lower control arms and the stabilizer bar bushings in the front end, and the watts links / bell crank in the back end. Any idea what else could be causing this noise?
Old 01 Jul 2012, 02:42 am
Vlefaive's Avatar
Default Re: "Popping" Noise when backing up
If you're from Michigan its probably mice................. jk.... why not get it on the hoist at a dealer?
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 01 Jul 2012, 06:47 am
A small search came up with someone suggesting to check the slide bolts on the front calipers.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
Visit My Home Page
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 01 Jul 2012, 10:05 pm
Thanks Crewzin. Most of the searches online suggest a caliper issue or motor mount issue. I'm not sure it really sounds like either, but I'll have someone else back it up, with the hood open and I'll try to get a better sense of where it's coming from.
"Thunk" noise when turning on the A/C VroomMaster Tech & Performance Forum 10 26 Oct 2016 06:47 pm
"Thud" Noise and Temperature VroomMaster Tech & Performance Forum 3 09 Sep 2011 09:04 pm
Turbo "phhsssss" or "whoosh" sound--Normal? Silenceable? Help! Memark General Turbo Discussions 13 24 Nov 2010 09:56 pm
advice on "noise" on bumpy roads... comPuTer General PT Cruiser Discussions 1 24 Mar 2009 02:40 pm
