06 Head Gasket Replacement
Old 01 Jul 2012, 08:43 am
Default 06 Head Gasket Replacement
Hey everyone, next week I'm going to tackle the awesome job of replacing the head gasket on my sisters 06 I was wondering if anyone has done this job themselves and would give me some advice if there is anything that will be unexpected. Also, if anyone knows of a step by step procedure that would be great as well! I appreciate any of the feedback! Thanks
Old 01 Jul 2012, 12:59 pm
UptownSport's Avatar
Default Re: 06 Head Gasket Replacement
Did a write up on an '01, think they changed direction of PS thru bolts-
Saw pics of removed Passenger's headlight to access-
Other than that, don't know what differences would be
Disconnect exhaust and jack passengers side engine WAY up, don't forget to disco exhaust manifold support from block, lift head/ exhaust manifold in one assembly
Old 01 Jul 2012, 01:45 pm
Are you sure you need too. And if you are, you prepared to replace the head if necessary? Also water pump and timing belt.
Old 01 Jul 2012, 02:26 pm
As was stated above, there is a headgasket "how-to" by UPTOWN in the top of the "Tech and Performance" section of this site. It's contained in the sticky marked as the "how-to's". As A matter of fact its in there twice. Its very throrough.
Jerry
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
Head Gasket Fix? Tn_Hogger Tech & Performance Forum 9 25 Aug 2011 12:10 pm
head gasket replacement and cam/crank relearn jhnhardee PT Cruiser Convertible Forum 0 18 May 2011 09:02 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
head gasket broadleaspeaking1 General PT Cruiser Discussions 1 27 Mar 2008 05:44 am
