Removing Dash under Steering column of 06 Convertible
Old 04 Jul 2012, 01:15 pm
Default Removing Dash under Steering column of 06 Convertible
I would like to remove the Dash under/aroundthe steering column to make some mods to it. What is easiest way to remove? Were are clips located? Any special tools needed?
Old 04 Jul 2012, 01:44 pm
Ray_Dockrey's Avatar
Default Re: Removing Dash under Steering column of 06 Convertible
The clamshell around the column comes off easy. There are two Phillips screws and one torx screw you get too from underneath. Before removing any more of the lower dash you need to find out if you have the lower knee airbags. If you do then you need to be very careful how you do anything under there.
Old 04 Jul 2012, 02:20 pm
Thanks for info. There is a panel that is directly under the steer wheel they may be an air bag so I m not sure I want to mess with it. I will check with local dealership. Thanks again.
Steering column cover - top AyeCantSeeYou Interior Accessories Forum 2 25 May 2011 04:13 pm
Locking Steering column while Driving Robino Tech & Performance Forum 1 10 Jun 2010 03:31 pm
Steering column noise elmeyer Tech & Performance Forum 1 20 Dec 2009 10:34 am
steering column noise 4SPEED General Turbo Discussions 2 12 Sep 2006 04:33 am
Click in steering column tcruiser General PT Cruiser Discussions 3 11 Nov 2002 12:25 am
