At what temps does the fan come on?
Old 09 Jul 2012, 07:25 pm
JenneK's Avatar
Default At what temps does the fan come on?
When should it come on on Low Speed and High Speed?
It seems to only come on when the AC is on. I'm watching it right now on my ScanGauge II and it is 200* and no fan action until I turn on the AC. Then the fan kicks on and the temps drop as it should.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 09 Jul 2012, 07:41 pm
Default Re: At what temps does the fan come on?
Personally, I would have though the low speed should have come on long before 200. but I don't know for sure. Never seen it in writing.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 09 Jul 2012, 07:49 pm
JenneK's Avatar
It just hit 207 and I heard a faint fan sound. Sure enough it was on. Turned on the AC and it sped up. So low speed at 207*?? Something ain't right...
Old 09 Jul 2012, 07:55 pm
According to this, the only thing that controls when it comes on is the PCM.
But we all know the A/C controls and the ECT (Engine Coolant Temperature) sensor have something to do with it.
Old 09 Jul 2012, 08:25 pm
UptownSport's Avatar
Chart; below 44MPH
Low on 206, Hi on 219
Low off 199, hi off 210
above 44MPH
Low NONE Hi on/off same as above
AC
Low NONE Hi on 180 Hi off 176
JenneK likes this.
Old 09 Jul 2012, 08:27 pm
Thanks to Uptown, your fan seems to be working normal. Except that I disagree (no matter what it says) about no low with A/C. My low certainly does come on with the A/C. Proved it several times.
Old 09 Jul 2012, 08:30 pm
This might be a good solution to the many problem post and threads I have read about electric OEM fans.
Most of the ECU or thermal relay controlled electric fans always seem to be more AI (artificial intelligence joke) then pre-set.
Easy to install and affordable.
This is one I like and use but there are a few on the market similar.
Take control back into your electric fan....
Flex-a-lite 31149 - Flex-a-lite Adjustable Electric Fan Controllers - Overview - SummitRacing.com
Old 09 Jul 2012, 08:47 pm
JenneK's Avatar
Originally Posted by UptownSport View Post
Chart; below 44MPH
above 44MPH
AC
Dude, that's the bomb!! Thank you very much! Now I know my fan works as designed.
Old 09 Jul 2012, 08:49 pm
With all the problems with fan controls here- It just makes my small head spin- that might be a good idea.
Engines LOVE to run hot, so don't get concerned if temp runs high-
I know we were all brought up on 180 degree 'stats, but even Smokey Yunick said competition engines (Running WOT) were best at 220-
Our intake isn't as tied to coolant temp as old V-8s
Old 09 Jul 2012, 08:53 pm
Secret: There's an 'e' FSM floating around-
see Chromenut or search google- Great Summer reading- Won't be able to put it down!!!
Crewzin', as you know, I don't actually know anything, just repeat what I've read. It did sound odd that low fan wouldn't run, perhaps it was only in context of cooling system section?!
NEW OEM Coolant Temps Sensors UptownSport Classifieds: For Sale/Trade 0 23 Oct 2011 12:27 pm
Air box temps blucruzer Tech & Performance Forum 2 28 Apr 2009 11:33 am
Heater and Missing since temps dipped in Ohio KIMS CRUZER Tech & Performance Forum 3 25 Jan 2008 06:06 pm
