jack stand locations pictures
Old 10 Jul 2012, 12:06 pm
Question jack stand locations pictures
Can anyone show me a picture of the jack stand locations. I'm changing the motor supports. Please
Old 10 Jul 2012, 09:53 pm
mdfrodolives's Avatar
Default Re: jack stand locations pictures
Assuming you're just lifting the front of the car, look a few inches past the back of the wheel well and you will see two triangular-shaped "darts", located at the rocker panel's flange--where you normalls put your jack. I actually jack up the car to the back of these two triangles and center the jackstands between the two triangles. All this area has metal that is twice as thick as the surrounding area. You can actually feel this sturdier area with your hands.
Sorry, no picks....
Old 10 Jul 2012, 10:41 pm
808's Avatar
808 808 is offline
What Tim said.
If you collect dirt under the car like an off-roader, wipe the area with a rag to find the triangles....I had to.
Old 10 Jul 2012, 10:43 pm
I much prefer to place the stands either under the suspension or the frame rails. Much more secure areas. Also your not contributing the rocker rust issue by chipping the pant up along the edge of the panel any worse than it already is. Also be sure to set the emergency brake before Jacking.
This is an example of the car being supported by the control arm.
Jack vs. jack stand locations bds02pt General PT Cruiser Discussions 1 28 Feb 2010 12:32 pm
Jack locations ptal General PT Cruiser Discussions 2 30 Nov 2009 12:25 pm
Jack locations? turbojerk General PT Cruiser Discussions 4 09 Nov 2009 02:58 pm
Jack stand question gonzomania General PT Cruiser Discussions 11 01 Oct 2004 10:40 am
Proper Locations for Floor Jack Stephen R. Tech & Performance Forum 13 02 Sep 2003 02:23 am
