MORE A/C issues
Old 11 Jul 2012, 09:22 pm
Default MORE A/C issues
Brief history, from another thread - fan went bad. High pressure blew out compressor. Replace compressor with new Mopar, fan with Dorman. Worked great for a couple of days.
Started blowing hot air again. Found refrigerant low, and dye stains around pressure valve. Evacuated and filled system. Saw a spike to 500 psi on high-pressure side (yes, fan's working). Let system evacuate overnight, to make sure it was as uncontaminated as possible. Charged system. 300 psi on high-pressure side. Let idle for half hour with A/C on. Fan was on low speed the whole time. Pressure climbed to 400 psi, but no hgher.
So, three questions:
1) At what pressure will the relief valve on the high-side bleed pressure?
2) Is 400 psi too high (idling for 1/2 hour isn't something I'd normally do)?
3) Does anyone know at what temp the high-speed fan comes on? We can trigger it with the scan tool, but haven't seen it come on via sensor/PCM. Maybe it runs cool enough with the low-speed; gauge doesn't go above half, for what it's worth.
'02 Limited, stock except for K&N and modified airbox, Crane FireWires
'06 Magnum SRT8, a few mods
Old 11 Jul 2012, 10:26 pm
Default Re: MORE A/C issues
This will tell you about the fan.
At what temps does the fan come on?
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 11 Jul 2012, 10:50 pm
Yeah, I saw that when I did the search There seemed to be some uncertainty regarding the high-speed fan, so I was hoping someone would have a more definitive answer.
Some issues with my car skolvikes1916 Tech & Performance Forum 4 06 Jun 2011 06:41 pm
A/C issues HO_Turbo Tech & Performance Forum 6 07 May 2011 12:10 pm
PCM issues I Think ??? Okuma Tech & Performance Forum 4 01 Mar 2011 05:05 pm
A/C issues... usmcwifey Tech & Performance Forum 8 07 Apr 2010 07:36 am
speaker issues, wattage of stereo, door speaker replacement issues fabes89 General PT Cruiser Discussions 9 02 Jun 2009 10:59 am
