2006 Turbo Lite - Whine in first gear
Old 16 Jul 2012, 12:06 pm
Default 2006 Turbo Lite - Whine in first gear
I have a 2006 pt cruiser turbo lite. It is an automatic with 55,000 miles. Just a week ago it seems that it has developed a whine while accelerating in 1st gear (RPM dependent). When it shifts to second, the whine disappears. It seems to shift fine otherwise and it isn't slipping. Anyone have any idea what this is?
If this is power steering related, I do have a secondary issue. The steering wheel has a slight whirring noise when it is turned. Its faint, but it is there.
Thanks.
Old 16 Jul 2012, 01:50 pm
UptownSport's Avatar
Default Re: 2006 Turbo Lite - Whine in first gear
I don't know how a PS issue would disappear with a gear change, although, of course, RPM's do drop.
You might wish to drop transmission pan and check for inordinately large shavings/chunks. (There will always be some, small metal shavings in ATX sump)
There's an 'e'-manual floating around that describes exactly what's inside that transmission in fairly simple terms.
Old 14 Jan 2015, 04:37 pm
Hi, did you find the problem in the end? I have a similar issue.
Thanks
whine when accelerating ,slips out of gear ipath1 Tech & Performance Forum 13 03 Jul 2012 11:13 am
2006 turbo lite Auto - Help locating S1 06turbolite Stage Turbo Kits 17 21 Mar 2011 09:22 pm
2006 vs other years and GT vs Turbo lite wendelltu General Turbo Discussions 10 10 Aug 2010 11:44 am
Uncommon Turbo whine turbomangt Turbo Performance 3 28 May 2005 12:09 am
Wasn't a turbo whine after all Mike-in-Orange General Turbo Discussions 9 03 Feb 2004 01:35 pm
