Poor acceleration, no power up hills
Old 16 Jul 2012, 11:19 pm
NuYork's Avatar
Default Poor acceleration, no power up hills
2004 Cruiser, having problems with poor acceleration going up hill. Poor throttle response. Idles fine. Sounds like it bogs down, tranny rpms around 4000 before it shifts. Any suggestions?
Old 16 Jul 2012, 11:34 pm
Default Re: Poor acceleration, no power up hills
sounds like what mine was doing 4 weeks ago until the idle went to hell too.
Its not your alternator :-D haha
Check the vacume lines, and your cat. i believe my issue is a clogged cat. has all the symptoms.
Oh and the idle air controler, Throttle position sensor and the EGR :-D
Old 17 Jul 2012, 02:35 am
JenneK's Avatar
How many miles?
Check engine light on?
When did it start with the symptoms?
Still using the same gas station as usual?
When is the last time a "tune up" was done (if mileage dictates)?
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 19 Jul 2012, 06:16 pm
NuYork's Avatar
118,000 miles engine light on and codes P0522 and P0420. I have already given it a tune up and replaced the oil pressure sensor. Issues started before tune up and still continue.
Old 19 Jul 2012, 06:45 pm
A clogged CAT will do exactly that, check it out.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 19 Jul 2012, 07:13 pm
Ray_Dockrey's Avatar
I agree with the clogged cat. I had a Trailblazer before my PT Cruiser and the early models were notorious for clogged cats and their symptoms were identical to what you are describing.
Old 19 Jul 2012, 07:50 pm
Only thing was the cat wasn't the real problem on most blazers. It was the spider injector unit. Open the exhaust they ran fine. Replace the injector unit and they ran fine with the exhaust on. None of this translates to the Pt though. Your probably right about the cat on this pt.
Old 19 Jul 2012, 09:25 pm
Wrong vehicle. The Trailblazer had a 4.2 dual cam inline six with variable cam timing or the V-8. They were produced from 2002-2009. They clogged because GM used to small a cat and they overheated and clogged. They fixed the issue in 2004. The reason it translates is because even though different vehicles the symptoms are identical and is a place to start. Trans shifts weird, no power especially up hills, and just a plain dog to drive.
Old 20 Jul 2012, 01:05 am
JenneK's Avatar
Hmmmm... 118K. I would replace the O2 sensor first. It is, afterall, why the P0420 code is coming up.
Old 20 Jul 2012, 07:23 am
Can the catalytic converter become clogged without throwing any codes?
My sister's black 01 non-turbo has the exact same symptoms: absolutely no power, even for a non-turbo; "putting" exhaust; poor milage, but no dashboard lights have come on. It only has 77k miles on it too.
Poor Mileage and Low Power... GangstaMobile Tech & Performance Forum 10 19 Mar 2012 06:03 am
misses bad, no power on hills and oil on plugs ashtrae311 Tech & Performance Forum 7 24 Dec 2011 03:33 am
shakey in drive, and on hills SaipanPT Tech & Performance Forum 1 22 Mar 2010 10:12 am
Granada Hills, CA Holiday Parade -- Dec. 4 Basset Hound Western PT Forum 0 23 Nov 2005 11:34 pm
Granada Hills, CA Christmas Parade -- Dec. 7th. Basset Hound Western PT Forum 0 02 Dec 2003 01:25 am
