Wheel Stud Replacement
Old 17 Jul 2012, 12:38 pm
kon's Avatar
kon kon is offline
Default Wheel Stud Replacement
Any tips how how to insert the Wheel Stud? I tried screwing it in but it does not go in. I purchased the right stud. Is there any tips? Trying to save some money from the mechanic.$50
Old 17 Jul 2012, 01:19 pm
Default Re: Wheel Stud Replacement
try placing the stud in the hole then tighten the lug nut. that should seat the stud. then remove lug nut and put wheel back on.
Old 17 Jul 2012, 01:23 pm
As soyomb just said, put the stud in from the back (if you can) put a lug nut on and screw it down until it pulls the stud all the way through the plate.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 17 Jul 2012, 01:53 pm
kon's Avatar
kon kon is offline
Thanks!
Wheel sensor replacement - how difficult? AndyJay General PT Cruiser Discussions 3 02 Jul 2012 06:35 pm
Wheel Bearing Replacement Poncho Villa Tech & Performance Forum 35 10 Jun 2012 07:09 am
wheel bearing replacement? clark200 Wheels, Tires, Suspension 1 17 May 2012 08:39 am
Wheel bearing replacement problems....need help srebik Tech & Performance Forum 7 26 Mar 2012 01:41 pm
16 vs 17 inch wheel replacement - Help, please! SusieQ Turbo Wheels/Suspension/Handling 14 26 Nov 2008 01:17 pm
