dead
Old 17 Jul 2012, 07:08 pm
Default dead
Drove to office this morning everything fine.went to leave dead battery? nothing left on.
Jumped it, started up but when i disconnected it gauges and interior lights went nuts jumping and flashing.it would stall when i idled it and had to re jumper it. battery is 3 years old..Alternator?
lt4 super
Old 17 Jul 2012, 07:14 pm
Default Re: dead
If stayed running after second jump, could be be corroded cable's on either end of the cable's not letting the charge get back to the battery.
Old 17 Jul 2012, 07:41 pm
Default Re: dead
this happened to me on friday. i got lucky and had my battery warrantied. someone, Crewzin i think, said there is supposed to be a heat shield of some sort around the battery. heat's a killer, tis' the season. for me the voltage tested fine, amps did not.
the way you wrote that it sounds like the alternator. charge the battery and test it with a volt meter. should be 12.8-14v with the car idling and at least 11.4 with the key off.
i ran my car with the battery disconnected before and it sputtered and died after a few minutes. (i know it's bad, but it was midnight and i was trying to get a friends car home) could be either one, but probably the battery.
Old 17 Jul 2012, 08:22 pm
Default Re: dead
No it died after second jump also unless at 2000 or so rpms but once idling to shift it dies off. with gauges and interior lights flashing and jumping around jumper cables got very hot.had to leave it 100 miles away from the house.i have never seen gauges and lights act this way.i could not check water leavel in batt as i did not have a long rachet extension to remove bracket..i have battery shield in good shape.will try in morning to start but sure it will be dead.
thanks for the replies
Old 17 Jul 2012, 08:39 pm
Default Re: dead
Anyone know what alldata says time wise to r&r the alterernator?
Old 17 Jul 2012, 09:06 pm
Default Re: dead
Found this in a search:
If the cables are real warm and you're not having success, it's a sign that your jumper cables have a problem. If they warm up, it means there's too much resistance in the line. There should be very little cable resistance. If the jumper cables are frayed or rusty at the clamps they won't work.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 17 Jul 2012, 09:21 pm
Default Re: dead
The same could be said for the battery cables in the car as well. Causing it to draw too many amps. All these thing connections should be gone over before you start throwing parts at it.
Old 17 Jul 2012, 09:23 pm
Badglas's Avatar
Default Re: dead
I agree with CREWZIN about the cables. You ask how long to change the alternator in your last post; did you determine that is the problem?
The symptoms you describe could also be a shorted battery. If you suspect that is the case, I cannot stress enough to be very careful. If you continually try to jump a shorted battery it can explode. Handle it with kid gloves! A shorted battery can also explode if it is jostled around.
The heat where I live has been terrible and is a primary cause of a shorted battery.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Is my PT dead? Marco421 Tech & Performance Forum 4 13 Dec 2010 09:34 pm
dead car klondikeone Tech & Performance Forum 4 09 Nov 2010 02:02 am
PT Dead - Need Help! silver7 Tech & Performance Forum 14 08 Mar 2010 11:50 am
Pt dead Maineiac General PT Cruiser Discussions 5 21 Jul 2009 11:05 am
Dead, again renichms General PT Cruiser Discussions 6 03 Jul 2003 11:42 pm
