HELP!!!
Old 18 Jul 2012, 10:59 am
Default HELP!!!
my pt broke down last night. i was taking a friend home from work and the car worked just fine. when i got to her house i turned the car off, when i went to start it up again i got nothing. no lights no clicks, no sounds or light of any kind. i called to get a jump and hooked her up to the battery, got lights and sounds, but no engine start. took the car off the battery and the car went totally dead again. also put anti freeze in the over flow container and it just leaked out onto the ground...any thoughts? am i going to have to donate an arm and a leg for this repair?
thanks for looking and for any responses.
Old 18 Jul 2012, 11:06 am
Default Re: HELP!!!
the overflow bottle has a drain to prevent overfilling. you can pour water in it for an hour and it will never reach the cap. it'll just pour out onto the ground through the drain tube(that you can't see).
Old 18 Jul 2012, 11:48 am
Default Re: HELP!!!
Did you check your fuses? Did you get any error codes?
Old 22 Jul 2012, 12:27 pm
Default Re: HELP!!!
didnt get any error codes or dash lights. only did the self test and it showed error 1684, i looked that up and its something like driver 5 line 4....wth? the issue was fixed by a mechanic....bad battery cable and wire. but i did the self test afterward and got the error code.
Old 22 Jul 2012, 12:56 pm
Default Re: HELP!!!
From PT Do-It-Yourself.net:
P1684 does not indicate a problem; it's only a status, which indicates that the PCM memory has been cleared within the last 50 ignition cycles.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 22 Jul 2012, 03:58 pm
Default Re: HELP!!!
Starter! :-D
Had this happen on my 99 neon sport.
Overheated. Died. had towed to a buddies, replaced thermo/fluid went to start. NOTHING. No lights, no power, no clicks when i turned the key. Jumped it. Got lights, took off the cables all dead again.
Turns the overheat had popped my Valve Cover gasket, thus leaking oil into the starter which shorted everything and killed it. When i took the starter out it was full of oil. Replaced VCG, put in new starter. Ran like a clock.
Try to jump it from the starter. If it works.......your starter is toast :-D
Old 22 Jul 2012, 04:28 pm
Default Re: HELP!!!
Quick question, or I think it may be quick. I have a 2006 PT Cruiser Touring. Was running fine and turned the engine off at a drive thru. Now it will not start. I have power to interior and lights. When you turn the ignition it does a click. Replaced battery and pos cable connector and was told to replace the relay switch. The relay switch I was given does not look anything like the part from the car and am not sure if I pulled the right part even. Where is the relay switch and what does it look like on a 2006 PT touring ed?
Thank you for any assistance.
Old 22 Jul 2012, 04:29 pm
Default Re: HELP!!!
You test your starter as well. as well as the ignition switch. Take your stock relay back to the parts store with you so you can match it up to the correct one.
