Last night my engine light came on (about 3 miles after i filled the tank w/ 93 octane) I checked the code this morning and it was P0129.
I don't see that code here: http://ptenthusiasts.org/troublecode.html any suggestions? 2003 GT |
Those codes are for the NA PT's not necessarily the GT's.
Anyway doing a search pulled this up: http://www.ptcruiserlinks.com/forum/...?TOPIC_ID=5834
PT powered PT with: Fully built HRC Turboed 2.4: Wiseco pistons, T2 rods, Port & Polished head (Bob Special) with oversize Stainless Steel valves, #14 Crane Cams, AF/X UDP, No balance shafts, Custom 3\" downpipe, 3\" hi flow exhaust, Ported GT intake manifold, Bored Throttle Body, 30 lb injectors, Water/Alc. injection |
Thanks Ant...I'll learn to use the "search". I guess just about everything has already been covered in these forums!!
My Scan tool says P0129 is "Low Barometric Pressure". I have this code too and am trying to find out if its the MAP sensor or if there are other sensors involved.
You've attached yourself to a 6 year old thread but I guess it goes along with what you have.
This is from PT Do-It-Yourself.net: P0129 - Barometric Pressure Out-of-Range low Description - MAP sensor input voltage out of an acceptable range detected during reading of barometric pressure. There are 11 possible causes listed in the diagnostic manual. It covers 3 pages of tests to determine the cause. I've replaced several MAP sensors. It's most likely a defect in the sensor. It's something that should be fixed ASAP.
| Mopar radio security code. | Ian-PT-GT | Sound and Security Forum | 11 | 24 Feb 2010 02:19 pm |
| Stall on freeway - code P00344? | tezz | Turbo Performance | 15 | 13 Aug 2008 05:21 pm |
| Need diag. code info | RIvey | Tech & Performance Forum | 1 | 01 Oct 2005 12:05 pm |
| BOV & P0443 code | Topless in Cali | General Turbo Discussions | 5 | 15 Aug 2005 06:06 pm |
| Fault code | RossiePT | General Turbo Discussions | 8 | 28 Mar 2004 10:52 pm |
