p0171, p0113, p128
Old 19 Jul 2012, 06:49 pm
Default p0171, p0113, p128
so i take the car to the shop to run a computer diagnostic , those 3 codes showed up , mechanic say's that
p0171 it's related to an oxygen sensor problem but i know there is 2 02 sensors on the pt's wich one i need to change upstream or downstream??
the p0113, it's about the IAT sensor and the mechanic say's the sensor is located in the pipe in the air filter to the throttle body it's that true?
p0128, refrigerant coolant sensor i already bought that but i still getting this code what can i do.
by the way the simptoms of my car are the following..
when first start it just simple doesn't start until 3 cranks up, sometimes it starts at first with out problem, sometimes at second but it runs in about 500 RPM and nothing happens if i got the pedal on the floor, when i put drive if i want to take out fast it simply shakes and stays about 700RPM the suddenly go off and hit the 2,000 RMP
what can i do i use this car dialy and i don't want to waste a lot of money guessing what the problem can be
Old 19 Jul 2012, 07:40 pm
Default Re: p0171, p0113, p128
The 128 is a coolant thermostat. Has nothing to do with ac. 171 is a lean condition. Better help is on the way.
Code P0113? unioncreek Tech & Performance Forum 2 24 Apr 2012 09:25 am
P0113 engine code pthead Tech & Performance Forum 0 29 Mar 2012 03:29 pm
P0171 and MAP sensor meder2487 Tech & Performance Forum 1 17 Dec 2010 03:45 pm
Please Help P0171 Code Still cusunfireguy Tech & Performance Forum 11 27 Jun 2010 04:17 pm
Code P0171 leftoverture Tech & Performance Forum 1 12 Jun 2009 06:17 pm
