Timing belt tensioner?
Old 20 Jul 2012, 08:53 am
Default Timing belt tensioner?
I removed the old timing belt tensioner last night. Are they supposed to be spring loaded? The old one I just used the allen wrench to turn it and it stayed put after turning. I haven't had a chance to look at the new one to see if it's spring loaded, but if their not how tight do you make the belt. I assumed they were self adjusting.
Bob
Old 20 Jul 2012, 12:00 pm
Default Re: Timing belt tensioner?
I don't know the make of your new tensioner, but I remember that the new one I put in my PT had a clip, so that when you install it, the tension is negative. When you install the belt, you pull the clip and that releases the tension. Hope this helps.
Timing Belt Tensioner ? SteveG22 Tech & Performance Forum 11 19 Sep 2012 12:46 am
Timing belt tensioner Jeepertim Tech & Performance Forum 9 25 Nov 2011 12:39 pm
Timing Belt Tensioner Areus Tech & Performance Forum 0 17 Jun 2011 05:44 pm
Timing belt tensioner slimjonesy General PT Cruiser Discussions 0 19 Mar 2011 06:35 pm
Timing Belt Tensioner 06ptbruiser Tech & Performance Forum 11 31 Dec 2010 10:39 am
