pt troubles
Old 20 Jul 2012, 03:52 pm
Question pt troubles
Hello
I bought a used 05 pt cruiser touring edition non turbo with 100k miles.
After a battery replacement things were going good (other than her gas guzzling)
A couple months later I'm driving to work at 4 in the morning, i get off the freeway and theCEL comes on and it starts hesitating. After visiting this site i learn my pt is in 'limp mode' i did the 'key dance' and pulled error code P0340. So i bought the part from the dealer and replaced it. Reset the codes. Car remained in limp mode. We replaced the spark plugs, spark plug wires, did a full tune up, car remains in limp mode. I have learned so much from this forum and i do love my pt, but what else can i do to pull her out of this?
Please help.
Old 20 Jul 2012, 06:49 pm
UptownSport's Avatar
Default Re: pt troubles
Here's from OBD codes
Hard starting or no start
Rough running / misfiring
Loss of engine power
Causes
A code P0340 could mean one or more of the following has happened:
a wire or connector in the circuit could be grounded/shorted/broken
the camshaft position sensor may have failed
the PCM may have failed
there exists an open circuit
the crankshaft position sensor may have failed
Possible Solutions
With a P0340 OBD-II trouble code, diagnosis can be tricky at times. Here are some things to try:
Visually inspect all the wiring and connectors in the circuit
Check for continuity in the circuit wiring
Check the operation (voltage) of the camshaft position sensor
Replace the camshaft position sensor as required
Check the crankshaft position circuit as well
Replace circuit wiring and/or connectors as required
Diagnose/replace the PCM as required
Old 21 Jul 2012, 11:31 am
Thanks I'll try those when i get home and let you know how its running
Old 21 Jul 2012, 12:06 pm
Talking Re: pt troubles
Why did you post under Stage Turbo Kits?
Old 21 Jul 2012, 12:23 pm
Not there any more.
Tags
limp mode, p0340
IAC troubles rob342 General PT Cruiser Discussions 1 16 Jun 2012 01:55 pm
06 troubles Jocko Tech & Performance Forum 4 26 Apr 2012 02:02 pm
Car Troubles PTCMIAH62 General PT Cruiser Discussions 9 07 Sep 2010 11:00 am
New guy... MBC troubles SRT Turbo Performance 3 02 Apr 2010 10:40 am
Lowering Troubles TemporeLegis General PT Cruiser Discussions 1 18 Sep 2007 02:37 pm
