Engine coolant leak help
Old 22 Jul 2012, 01:40 pm
Default Engine coolant leak help
Hi all
Me and my husband just brought a 2001 PT Cruiser which had no records of service history. So we decided to get it looked over at a garage just to see where we at, of course being a second hand car there are problems. Cutting the story short we decided to fix the important things first because we have 2 kids (safety first) and money is tight. At this point the car did not overheat... Wierd thing happened, we got someone to flush out the system and add new coolant. Barely a week after the car overheated, at first we thought maby he didn't put enough coolant in so we added more to the coolant reservoir which was empty. After waiting for car to cool we drove it home and it happend again, then i popped the hood and the coolant reservoir was BOILING! Next morning we found a leak on the left side of car (facing front) and the fresh new coolant was leaking very slowly.
I have checked for leaks around the reservoir, thermostat any anything above but after looking the leak is coming somewhere underneath from where the timing belt is.
Please note its a uk reg car so driving position is on the right side.
Thoughts anyone??
Thanks Tori
Old 22 Jul 2012, 03:49 pm
Stempy's Avatar
Default Re: Engine coolant leak help
Well the water pump is down there and possibly the source of your leak. This is bad news as the water pump is driven by the timing belt so is a labour intensive job = expensive. Depending on the mileage you would need pump, belt and tensioner replaced. BUT, it might just be a split hose, so worth having a closer look.
Some things to note, coolant should be the red stuff not the blue stuff and these should never be mixed. The plastic thermostat housing can microcrack and leak slowly. Radiator caps go bad also and can vent coolant at too low a pressure.
As a stop gap measure it's worth adding a bottle of Bars stop leak as this will plug any small leaks in the system, but if your pump has gone then replacement is the only option.
2004 PT Cruiser Limited 2.4L
Old 23 Jul 2012, 01:44 am
Our car has done just over 51 k and I think it's due very soon maby sooner. Not really what I wanted to hear but we're waiting for some some to have a closer look as I can see my self.
What I don't understand is, the car was fine before. Didnt overheat... Now it does. I'm just hoping its a quick fix
Old 23 Jul 2012, 02:42 am
Badglas's Avatar
Bars leak can be a short term fix, but in these cars it tends to aggravate and/or cause long term problems. I would get a proper diagnosis and repair the problem. Stop leak products rarely stop a water pump seal from leaking for any length of time, if at all.
Good luck! Keep us posted.
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 23 Jul 2012, 03:00 am
Stempy's Avatar
Well it will quickly overheat if the coolant has leaked to a level where the header tank is empty. If it seems to be full and still overheats you may just have an air lock, or the flushing of the system has plugged it up somewhere.
Does the heater work?
Old 23 Jul 2012, 10:23 am
Yes the heater works which confuses me. The fan kicks in too so I'm guessing the thermostat works?? There is no coolant in the header tank as most or all has leaked. I'm getting someone to have a look for us to see.
I'll let you guys know thanks for reply's and help
VIcky
Old 23 Jul 2012, 11:27 am
UptownSport's Avatar
IIRC, you can see weep hole for water pump if you crawl under
Old 25 Jul 2012, 02:31 pm
Weird thing, had someone come to check the leak and it had stopped! There is now no sign of any leak and after we refilled the tank and drove it up the road and back, the tank is still full and no leaks. What's happened?
Old 25 Jul 2012, 02:44 pm
What's happened?
Stranger things have happened.
You go to the doctor with a back ache and it's gone when you get to see him. The tooth ache goes away while waiting for the dentist.
Maybe it only leaks when everything is hot and when you had someone come to look at it, it hadn't heated up yet.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 25 Jul 2012, 04:22 pm
Yeh maybe. all hoses and water pump checked and no sign of any leaks from there ... The a/c line had been cut though?? Would that have any bearing on leaking from the system?
It was a really hot day when I drove it last and the coolant seemed to go right through the system within a matter of minutes yet today it's stayed put. I'm so confused??
Coolant Leak TimWeaver Tech & Performance Forum 6 13 Jul 2012 08:55 pm
PLz help= Coolant leak PtC06 Tech & Performance Forum 2 04 Dec 2010 02:01 am
Coolant Leak dfales General PT Cruiser Discussions 7 18 Dec 2009 06:30 pm
Coolant Leak rcalzadilla Tech & Performance Forum 29 25 Oct 2009 01:29 pm
coolant leak RaceWilson Tech & Performance Forum 7 14 Sep 2008 09:49 am
