Radiator Bleed Valve issue
Old 25 Jul 2012, 12:50 pm
Default Radiator Bleed Valve issue
So my boyfriend was bleeding the air from the lines because my car had been overheating... well the valve popped off and we can not find it anywhere, so i call the auto parts store who says thats a dealership part only then i call the dealership who tells me that a 2002 pt cruiser does not have any type of bleed vavle or bleed screw or bleeder nipple.. so my question is how do I get a new one??
Old 25 Jul 2012, 01:08 pm
Default Re: Radiator Bleed Valve issue
I'm not one to disagree with the dealer but I'm pretty sure all PT's came with a bleed valve and as far as replacing it, any decent auto store should carry a supply of different size nipples for bleeding and adding grease to ball joints.
Somehow, take one of these pictures to the auto shop to show him what you looking for.
After you find one and put it back in so your boyfriend can finish the job, take the picture and throw it in your dealers face.
Only kidding.
...just CREWZIN along! . . . PT Cruiser Links Moderator
2000 PT. Original Owner, 123,000 miles
MY technical suggestions are given in GOOD FAITH without total guarantee, if in doubt go to a garage.
Cruiser Of The Month (COTM) May, 2015.
I find it ironic that the colors red, white, and blue stand for freedom until they are flashing behind you.
Old 25 Jul 2012, 01:11 pm
yeah i told the guy he needed a new job cause we had just taken it off the car, but it doesn't have to be a chrysler part like autozone told us?
Old 25 Jul 2012, 01:17 pm
UptownSport's Avatar
It's just a brake bleeder-
Either 3/8 28 or M9x1
See if I can narrow it down for you
And dealer part number is:
Old: 3780788
New: 5015248AB
Old Part Number 3780788
New Part Number 5015248AB
Part Name BLEEDER BRAKE
MSRP $3.70
Always remember, Dealer= Expensive Idiots
Your local parts house will have an entire bin they'll let you try
Old 25 Jul 2012, 01:18 pm
I sure wouldn't think so. They should have a drawer full of them or nowadays everything comes in a sealed off packet hanging on a hook.
Old 25 Jul 2012, 01:33 pm
Well this is great news and I have someone on the way to pick my bf up to get the part thanks for the info.. my bf is like MacGyver so he was able to to make something showing the exact size we need to fit..
Old 25 Jul 2012, 01:53 pm
I should do a thread on "auto parts employees"
I know that it is frustrating if the CSR can't locate it on the parts look up system and they are not sure what the parts is. They all seem to use this or similar terms and phrases to escape having to assist you further. "ITS A DEALER PART".
My personal favorite is when the part I need has nothing to do with its original intended and manufactured application and after explaining in detail this to the CSR they still will ask me "whats it going on"?
My reply looking them straight in the eye with all the sincerity and patients I can muster up at that moment.... an "elctrofragistat".
Not to worry to much, Your missing bleed valve will show up a year or so from now when you are changing a radiator hose or something else and there it will be just sitting there carefully preserved and now no longer needed!
Old 25 Jul 2012, 07:24 pm
mdfrodolives's Avatar
By the way, you needn't unscrew the bleeder valve while bleeding the system. You just turn it a bit counterclockwise till is squirts. I also attach a three-eights inside diameter clear hose to this valve. That way when I bleed the system, the coolant doesn't get all over my belts and ruin them with terminal squeeks. Being clear, I can see when all the bubles are gone ....
Tim
cooling system bleed valve dayle777 Tech & Performance Forum 5 09 Jul 2011 11:10 am
How to bleed coolant system on 2.0 PT Cruiser xr3tf Tech & Performance Forum 3 15 Nov 2010 02:22 pm
2002 Touring - 1st time oil change at home. Any diagrams of the oil bleed and filter? scottv General PT Cruiser Discussions 8 14 Jul 2010 09:06 am
How to Bleed thePower Steering System ptrican General PT Cruiser Discussions 1 17 Feb 2010 09:21 pm
