O2 Touring horn fuse & relay location
Old 25 Jul 2012, 02:30 pm
Exclamation O2 Touring horn fuse & relay location
Just bought an 02 Touring edition but my horn doest't work & nothing happens when I push panic on the key fob. Checked cover for fuse to left of my knee inside car & doesn't list horn at all. Is it under the hood?
Also, are these suppose to roar like a sports car when accelerating or do I possibly have an exhaust issue?
Thanks
Old 25 Jul 2012, 02:47 pm
Default Re: O2 Touring horn fuse & relay location
Welcome to the forum.
The "roar" is either caused by an aftermarket exhaust or an aftermarket intake. Most likely the intake the way you described it. The stock PT is quiet.
The horn relay IS in the engine compartment in the PDC (Power Distribution Center) under the air filter. It's the Letter "A" in all the relays and the fuse is No#14.
Old 26 Jul 2012, 07:19 pm
Thumbs up Re: O2 Touring horn fuse & relay location
Thanks so much! Now I can check & see if I can find the problem. Your also right about the exhaust as I saw a mechanic today. Meeting up again next week as he wants to check my belt under some covet. He says that mfg suggest replacement between 75k- 112k miles & since it has 113k & no service records he is going to check it. I pray the previous owner replaced it as its a $500 job.
I did minor stuff today - replaced driver fog light, tail light & brake light, but for a chick tats as mechanical I get. 😉
Waiting till tonight to check tire pressure as it was in high 90's today.
Thanks again
Tags
fuses, horn, relay
What is relay location??? dwpate5 Tech & Performance Forum 25 01 Jul 2013 08:51 am
Relay location? decoyboy Tech & Performance Forum 1 22 Jul 2011 06:30 pm
Location of 2009 Horn Relay James001 Tech & Performance Forum 4 20 Apr 2011 02:30 pm
'06 A/C fuse & relay location? FlaKeysMac Tech & Performance Forum 2 21 Feb 2010 12:40 pm
Where is headlight relay fuse om 06 PT Touring outfit Exterior Accessories Forum 4 08 Feb 2009 07:08 pm
