My 5-spd PT occassionally refuses to rev above 2800RPM?
  • 1 Post By Yeffsie
Old 25 Jul 2012, 08:57 pm
Default My 5-spd PT occassionally refuses to rev above 2800RPM?
Hey, so, I've had my PT for about two years, got it with 45k miles and it now has 107k. 2004, base wagon, five-speed manual. Sometimes (whether accelerating or cruising) the car will jerk down to 2800rpm, and I can still drive it under that rev limit, or I can also turn the car off and kick-start it with my momentum and everything seems to reset itself, sometimes for a few minutes, sometimes for a few days.
Any help? seems like the computer's miscalibrating or it's got a bad spark somewhere or something.
Old 25 Jul 2012, 10:07 pm
Talking Re: My 5-spd PT occassionally refuses to rev above 2800RPM?
Do the key dance, see if it's throwing codes. Just guessing tho it could be ur cam sensor, if u haven't had it replaced now would be a really good time along with timing belt and water pump. But make sure u only use a factory cam sensor.
Purple 2005 PT GT ATX w/ Mopar stage 1 PCM, Diablosport 93 oct tune, airbox mod, K&N drop in filter, Mopar BOV, AGP wastegate (8 psi spring), Custom made stage 1 camshafts, motor mount inserts, NGK Iridium plugs, MSD wires, ARP Head Studs, Gates Racing Timing Belt, AC Delete kit, purple painted Valve cover, Rebuilt (stock) Turbo , AEM Boost, Oil Pressure, and Wideband guages, triple guage A pillar pod, Strut Tower brace, Needswings 3in o2 housing, 3in downpipe w/ high flow cat and electric cutout, 2.5in Magnaflow catback, custom check valve, custom larger capacity trans cooler w/ built in cooling fan, Eibachs pro lowering springs, KYP front and rear struts, matte black hood and grille, gloss black stock SRT neon rims, purple lug nuts, blacked out tailights and reflectors so far. Built and bored out motor, AGP S256 turbo, ported cylinder head, and built trans soon to come.
Old 26 Jul 2012, 10:25 am
Default Re: My 5-spd PT occassionally refuses to rev above 2800RPM?
Yeah, I ran a scan with my OBDII this morning and my csps is definitely the source of the problem. I'll have a new one in later today and verify if that fixes it.
NicksCruiser likes this.
2004 5-speed manual 2.4L n.a.
Old 26 Jul 2012, 09:17 pm
Glad I could help!
P0340 & P1391 code // cold start & occassionally stalls apalomo01 Tech & Performance Forum 13 28 Jul 2012 08:00 pm
Another dealer who refuses to install Stage I TripleJackInGA Stage Turbo Kits 12 28 Nov 2003 04:02 pm
Dealer Refuses to Install Stage I Adman Stage Turbo Kits 7 13 Sep 2003 04:41 am
