transmission delemia
Old 26 Jul 2012, 06:34 am
mdskinner731's Avatar
Default transmission delemia
driving along yesterday crewsin down the highway (70-75mph)
my car decided it was a great time to down shift to first gear. skidding front tires. tach pegged. and no controll for close to 75 feet?? the car actually stopped running for a few seconds untill i put it in neutral. fired right back up but had a check engine code?? P0505. so far as i can figure it is a IAC (Idle Air Control) code. car still idles shifts smooth and has no issues. are these 2 things completley un related or did something fault?
if it moves and not supposed to... duct tape!!!
if it dont move and is supposed to... WD-40!!!
~* the problem with america is warning labels.... take them off of every thing and eventually the stupid people will die off... *~
Old 26 Jul 2012, 06:40 am
Default Re: transmission delemia
Change the Idle Air Control Valve.
And change the VSS *vehicle speed sensor* this is the part that tells the car when to shift depending on speed :-)
That should fix your wagon :-)
Old 26 Jul 2012, 06:54 am
Manual
Automatic
Old 26 Jul 2012, 07:01 am
Originally Posted by CREWZIN View Post
Manual
thief :-p haha
Old 26 Jul 2012, 07:08 am
Originally Posted by pluminator View Post
thief :-p haha
No, No, No. Great answer on your part. Just trying to show the poster where the VSS is, added automatic trans. Yes, I did steal the pictures from Mr Haynes.
Old 26 Jul 2012, 07:09 am
changed the IAC sensor last night... (robbed it outta my moms car..)
i will have to change that VVS too. has anyone ever had this happen to them before?
thank you! ~ mike
Old 26 Jul 2012, 07:12 am
thank you! ~ mike
YES.
Transmission shifting in to low gear problem
(just passing it on, didn't read it)
Old 26 Jul 2012, 12:55 pm
UptownSport's Avatar
So you got your 2.4 tested to 10,000 RPM!
A few months back someone complained of trans 'locking up' going down freeway
He complained of a dangerous defect but refused to let Chrysler look at it and had it repaired.
The difference between 'locking up' and shift into low at highway speeds would be only semantics to occupants!
tire delemia... mdskinner731 Tech & Performance Forum 1 29 Mar 2012 12:51 pm
Need Transmission help!! jennylyn General PT Cruiser Discussions 0 20 Oct 2008 07:05 pm
transmission lotta Tech & Performance Forum 6 29 Sep 2005 08:44 pm
Transmission Went Mean Green General PT Cruiser Discussions 8 16 Oct 2004 11:49 am
transmission fyrebuster General PT Cruiser Discussions 5 28 Jul 2003 01:11 am
