Brake problem
  • 1 Post By swanjack
Old 26 Jul 2012, 06:43 pm
swanjack's Avatar
Default Brake problem
Hi Guys,
After driving for about an hour and a half today, I felt that something was just not right in that it felt like I was driving with the brakes on. So I pulled over and found smoke coming from the left hand side front wheel, and the rim was seriously hot. There was a real foul smell as well, which I assumed to be burning brake pads . I jacked the car up and sure enough the wheel would not turn, the pads had bound to the rotor. I let the car cool down for about 20 mins, and the pads released the wheel and I managed to drive home, using the hand brake and minimal brake pedal.
When I replaced the pads and rotors about 200 miles ago ,I had real difficulty in pushing the calipers back in, but they went back all the same. The caliper bolt pins seemed to be okay.
So could I have a sticking caliper, or could the rubber brake line be breaking down, or could there be anything else??
Thanks for any advice.
Old 26 Jul 2012, 08:05 pm
UptownSport's Avatar
Default Re: Brake problem
Originally Posted by swanjack View Post
I could have a sticking caliper, or could have the rubber brake line breaking down,
You're correct; you can re-man caliper yourself for like $5
Old 26 Jul 2012, 11:18 pm
I would suggest replacing the caliper, the rotor *especially if there was smoke* also the Brake hose leading into the caliper.
What happens when a caliper or rotor gets too hot is it will actually boil the fluid inside of the intake line, and bubble the rubber, thus blocking the flow of fluid. Mix that with a stuck caliper.......even if you replace the caliper alone you will have a failed brake on that side. :-)
Old 27 Jul 2012, 01:17 pm
rcktpwrd's Avatar
I had this happen to both front calipers at different times. I got rebuilt calipers from the parts store and all was well, along with bleeding the brakes as the fluid had boiled.
Joel
2001 PT Cruiser 5-speed; 1976 Oldsmobile Cutlass S; 1990 Chevy 454SS
www.rcktpwrd.com
Old 27 Jul 2012, 02:07 pm
swanjack's Avatar
Thanks for the replies guy's. Have bought a kit to do both front calipers and new brake hoses for both sides. Got them from Rockauto. Should get them in 5 days as I'm in the UK. Even with shipping, its 60% cheaper than buying from my local dealer .
rcktpwrd likes this.
Brake bleeding problem please help!! cvessells78 Tech & Performance Forum 0 12 Jan 2012 11:01 am
Help! Brake Problem. Pushpin General PT Cruiser Discussions 8 09 Jan 2012 04:51 am
Brake light problem Cruiserbob General PT Cruiser Discussions 3 10 May 2011 12:27 pm
Brake light problem Shiniquiet General PT Cruiser Discussions 4 24 Sep 2010 07:05 pm
Strangest Brake Problem ptcarter Turbo Wheels/Suspension/Handling 5 13 Apr 2009 07:17 pm
