2005 GT TURBO will not turn over
Old 28 Jul 2012, 06:53 pm
Default 2005 GT TURBO will not turn over
Hello I am new to this. Please for give me if I mess up. I have changed out the actuator pin due to car not turning over and now the car started right up and cut off after about 5 sec. It did that two times now i am back to square one. The car will not turn over all lights work but nothing at the engin can some one please Help me.
Old 28 Jul 2012, 07:03 pm
Default Re: 2005 GT TURBO will not turn over
If the engine cuts out after a few seconds, that's a sign that the security system doesn't recognize the right key. It thinks your trying to steal the car. Do you have another key you can try?
Old 28 Jul 2012, 08:50 pm
I have a new ignition cylinder i can install and it came with a key.
Old 28 Jul 2012, 08:56 pm
I original replaced thr cylinder, then the switch ti figure out it was the actuator pin so I put the old cylinder back in cause i am not sure how the key thing works with the keys it came with
Old 28 Jul 2012, 10:15 pm
767skyking's Avatar
Take the new cylinder and have it keyed to the old key. It is less cost to do it that way then to have a new key programmed
Old 29 Jul 2012, 09:10 am
so do you think its my old cylinder and key causing this problem
2005 PT will not turn over lukeamiller Tech & Performance Forum 0 28 Nov 2011 07:18 pm
Is it possible to turn my pt into a gt with a turbo thatsmrjptou Tech & Performance Forum 3 21 May 2010 11:20 am
2005 turn signal problem ricksterw General PT Cruiser Discussions 7 18 Feb 2010 05:59 pm
Turbo does not turn! Tom and Marj Green Wheels, Tires, Suspension 12 03 Jan 2006 11:09 pm
blue turn signal bulbs that turn orange when in us Capt Kidd General PT Cruiser Discussions 1 04 Jun 2004 10:10 pm
