Blowing coolant back into overflow!!
Like Tree2Likes
Old 30 Jul 2012, 08:48 pm
Unhappy Blowing coolant back into overflow!!
My 2005 non turbo PT has been giving me fits during the last 6 months or so. The coolant reservoir is slowly filling and not returning to the radiator. I have been manually pumping back from the tank to the radiator. My first thought was a bad radiator cap but a new one didn't help. Being it has 150,000 miles on it my second thought was a warped head or blown head gasket. I had the head rebuilt and shaved and spent a full weekend carefully putting it all back together. I am not a professional mechanic but have done this many times. It is still pushing back anti-freeze. The car never heats up unless I let the radiator gets to low. (BTW the radiator, thermostat and water pump have all been changed recently also). I haven't checked the small filler hose to the tank but I don't see any leaks that would cause the loss of suction. Anyone got any ideas out there? I really don't want to take this baby apart again. The machinist is very thorough and seems to do a good job so I am assuming the head is good. I have also purged the air from the system and checked the fans.
Old 30 Jul 2012, 09:15 pm
Default Re: Blowing coolant back into overflow!!
Have you checked the plastic housing that the cap fits on for cracks? Seem you have all other bases covered. Very good information.
Old 30 Jul 2012, 09:16 pm
Welcome to the forum.
You've done everything right and assuming it's all correct, there should be some sort of air/coolant leakage. Go ahead and check thoroughly the filler tube and look carefully under the radiator cap for signs of leakage.
Old 30 Jul 2012, 09:53 pm
Badglas's Avatar
I know I keep saying the same thing over again, but; have you visually checked the hose between the reservoir and the engine? I've posted this several times, but I had similar problems and that was the cause. A small hole in this hose would cause your exact symptoms.
Welcome to the forum!
2001 PT Cruiser Limited Auto Stock
"Political correctness is a doctrine, fostered by a delusional, illogical Minority, and rabidly promoted by an unscrupulous mainstream media, which holds forth the proposition that it is entirely possible to pick up a Turd by the clean end". (R.J. Wiedemann Lt.Col. USMC Ret)
Old 30 Jul 2012, 10:09 pm
He did mention it so i didn't go there, although it would be very hard to see. Might be worth another look.
Old 30 Jul 2012, 10:14 pm
He did mention it, yes, but he said he didn't check it, that's why I said it also.
Old 31 Jul 2012, 06:50 am
I think I will replace the overflow tube reguardless. They are cheap enough. I will check the filler tube tonight. There isn't any oil/water mixing nor any steam/smoke coming from the exhaust and those are the usual tell-tale signs of a head problem. I'll keep you posted.
Old 31 Jul 2012, 07:40 am
Ya, CREWZIN I saw have at the end of that list instead of haven't!
Old 31 Jul 2012, 10:03 am
767skyking's Avatar
Did you purchase an OEM cap? I have found that some caps do not seal correctly, in addition, trying it on an aftermarket radiator might not work.... I use nothing but Chrysler caps now.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 31 Jul 2012, 10:31 am
The cap is on the engine on these.
Coolant Overflow Tank Turbo/Non-Turbo? DriftWoody General Turbo Discussions 5 06 Aug 2012 10:43 am
Coolant overflow tank, hmm.. Kawizx9r General PT Cruiser Discussions 2 16 May 2012 04:44 pm
Overflow coolant hose Flowrider General PT Cruiser Discussions 2 12 Dec 2011 09:47 pm
Coolant overflow woes! Bottle help needed. 03GTCruiser General PT Cruiser Discussions 2 06 Jul 2011 03:09 pm
Radiator overflow zaboha Tech & Performance Forum 13 08 Nov 2010 03:46 am
