Engine light on after new battery
Old 01 Aug 2012, 12:01 pm
Post Engine light on after new battery
Woke up this morning to the car not starting we were getting the clicking from the starter. We replaced the battery and the car started up like a champ. however the check engine light is now on. could there be something that we need to reset or is there something more going on there???? Help please!
Old 01 Aug 2012, 12:24 pm
Default Re: Engine light on after new battery
If the engine light is on, you have a fault code stored in the computer. Follow the instructions and tell us what the code is so we can help you.
How to retrieve fault codes.
Old 01 Aug 2012, 02:01 pm
767skyking's Avatar
Once in a while, on the pt's, if the engine takes longer to start, the pcm will trigger a start code, but once a new battery is installed, it will not reoccur after clearing. I do not have that code at this time. I will search
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 01 Aug 2012, 02:51 pm
Thanks for the reply will try that this evening and see what the code comes up with. In the mean time what simple inexpensives things can i do to sup this puppy up. any recomendations?
Old 01 Aug 2012, 03:32 pm
If it's a non-turbo, almost nothing. If it's a GT or a Turbo Lite, plenty. You told us nothing about your car.
Old 01 Aug 2012, 05:54 pm
If the battery voltage drops too low (which it did since it was dead), it will often set a battery voltage code and trigger the engine light. All you need to do is clear it.
-Chris
Battery light jackski Tech & Performance Forum 10 03 Jun 2013 07:12 pm
battery light dewey68 Tech & Performance Forum 3 05 Jul 2012 09:54 am
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
Battery light sacha33 Tech & Performance Forum 6 12 Mar 2007 07:44 am
