Best Way to get crankshaft pulley bolt
Old 01 Aug 2012, 01:13 pm
Default Best Way to get crankshaft pulley bolt
About to start mi timing belt water pump removal/install and i wonted to kno whats the best way to get that crankshaft pulley bolt off easy
Old 01 Aug 2012, 01:54 pm
Default Re: Best Way to get crankshaft pulley bolt
I used an impact wrench on my compressor. You can also just use a socket and jam a screw driver through the slot in the dampener to hold it. Just make sure that you will not damage anything with the screwdriver.
Bob
Old 01 Aug 2012, 01:55 pm
767skyking's Avatar
You must use a QUALITY remover for the harmonic balancer. Autozone rents an actual Chrysler remover that is made for the process. Do not try and use a 3 prong that mounts to the edges. You will break the edge of the harmonic balancer, then you will be forced to spend about $60 for a new one at the dealer.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 01 Aug 2012, 02:15 pm
I just used my regular three arm puller and was able to fit it in the slots. I've hear the Chrysler pullers need to have something that 1/4 inch slid in behind them so they don't slip off.
Bob
Old 01 Aug 2012, 02:29 pm
767skyking's Avatar
Wow Bob... You must have a quality 3 prong. My first one snapped, them I just got a "snap on" made for the 2.4. And yes, I use 1/4 sockets wedged to hold tight.
Old 01 Aug 2012, 03:15 pm
JenneK's Avatar
Bob
I couldn't get a screwdriver to hold anywhere. So I just put a breaker bar on the bolt and rested the other side against the control arm and cranked the engine over to break the bolt loose.
The rented Chrysler puller will require a longer bolt to fully remove the dampner. The ones in the kit are not quite long enough.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 01 Aug 2012, 05:04 pm
UptownSport's Avatar
I used the Mopar puller for years as they said a standard puller wouldn't work;
quite the opposite, I found the sears craftsman puller to be BETTER than the Miller tool.
As JenneK said, the inserts aren't long enough, and people have messed up crank trying
(use a passenger's engine mount thru bolt from a Neon; Free at Junkyard!)
Old 02 Aug 2012, 06:57 pm
I've heard with the Chrysler pullers that you need to take a 1/4" or 5/16" bolt and cut a section about an inch long and insert it into the hole in the bolt to get it fully off.
Bob
Old 02 Aug 2012, 07:03 pm
If you're using Miller tools just use the OE bolt and/or the Neon motor mount bolt.
I've seen dozens of Neons with 'something' sticking out of crank bolt hole in JY's.
Sad.
Special tool necessary for Installing Crankshaft dampner pulley? 2001PTCRUZ Tech & Performance Forum 4 14 Jan 2013 10:12 pm
Crankshaft pulley bolt & engine rotation direction JenneK Tech & Performance Forum 6 30 Jun 2012 03:17 pm
Crankshaft pulley Bobwalker Tech & Performance Forum 3 09 May 2012 06:43 pm
crankshaft pulley removel fugittj Tech & Performance Forum 4 29 May 2005 12:36 pm
crankshaft pulley removel fugittj Tech & Performance Forum 0 01 Jan 1970 12:00 am
