Random Engine Troubles Tonight
Old 01 Aug 2012, 09:47 pm
Default Random Engine Troubles Tonight
So, to cap off a great day, I just went to go pull out of a parking spot with my '01 Limited and noticed something weird right away. My car was rolling kind of slow. Shortly after I started rolling, the check engine light came on. Then realized the engine would rev itself up and kind of jump back and then slow down again. The car started doing the same thing in drive after just trying to see how it rolled around the parking lot. When trying to brake, the car stops to a very very slow roll suddenly and the steering locks up. I have absolutely no idea what's going on, and I'm having a buddy of mine look at it tomorrow. Anybody have any ideas?
Old 02 Aug 2012, 03:32 am
Kawizx9r's Avatar
Default Re: Random Engine Troubles Tonight
Key dance = engine codes = possible causes.
Without the engine codes your car has stored, we can only guess at what the issue might be.
Kawi is a friggin genius!
Old 02 Aug 2012, 03:55 am
Sounds like somebody was messing with your car. You have to many things going on at the same time. Engine, breaks, steering. Start with the engine light as Kawizx9r just said and go from there.
Old 02 Aug 2012, 09:13 am
767skyking's Avatar
Without seeing it would be hard to diagnose, but sounds like you have variable rpm's. I have seen something like this on one of ours and it turned out to be the TPS (throttle position sensor), but like again, tough to diagnose without seeing and more info
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 02 Aug 2012, 10:42 am
So I wound up getting the code of P0601 as well as P1684...hopefully this is an easy fix?
Old 02 Aug 2012, 11:00 am
Ray_Dockrey's Avatar
P1684 means that the battery has been unhooked and the memory has been cleared so it is a non issue. The P0601 means the ECM has had some kind of internal issue. I would unhook the negative cable from the battery, leave it unhooked for thirty minutes or so and then hook it back up and see how it runs and if that code comes back.
Old 02 Aug 2012, 11:13 am
A new step to that clearing the code is to step on the break peddle while the battery is disconnected to get rid of any residual charge.
Old 03 Aug 2012, 01:54 pm
Codes were cleared and everything today, and the problem persisted...The car is at the mechanic now Hopefully it won't be too expensive
PT Random Engine Shutoff KrisPTCruiser Tech & Performance Forum 6 01 Jun 2016 02:06 am
Random check engine light ptguy69 Tech & Performance Forum 3 19 Oct 2010 03:06 pm
Took the GT to the dyno tonight BoostJunkie General Turbo Discussions 3 05 Aug 2008 08:57 pm
One more pic for tonight I'm having so much fun careyk General PT Cruiser Discussions 4 04 Jun 2008 01:58 pm
Everybody wanted a ride in my car tonight! Mike-in-Orange General PT Cruiser Discussions 7 27 Mar 2004 02:50 am
