About ignition leads
Old 02 Aug 2012, 06:03 am
Default About ignition leads
Goodmorning everyone. I am new here. I have a question. I need to change my ignition wire on my 06 Cruiser (named her Jenny). Do i go for factory ones or on aftermarket? I am from Greece so my choices are limited. Any recommendations?Thanx a lot and keep cruisin'.
Old 02 Aug 2012, 09:16 am
767skyking's Avatar
Default Re: About ignition leads
I'm an OEM guy when it comes to wires and I know we will get some feedback on this. It would take too long to explain.
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 02 Aug 2012, 09:26 am
Can you post what your choices are in your local area? It would help to give us an idea on what to recommend as you say you have limited choices.
Old 02 Aug 2012, 10:48 am
OEM wires are garbage and they are known to go bad after a few thousand miles...You can use any good aftermarket wires, like Bosch, NGK, etc on a N/A PT
Old 02 Aug 2012, 06:53 pm
mdfrodolives's Avatar
Buy Bosch. You're bound to have them in Greece. I replaced mine using them and they snap in like they should and work great.
Tim
XtrmDC2 likes this.
Old 03 Aug 2012, 02:05 am
Guys my chooices are the OEM that costs 100 Pounds (in Greece 125 Euro) and i saw the Magnecor KV85 in UK 58 Pounds. I didn't find anything else.I don't what prices you have in your countries but i think 100 Pounds for OEM is too much. I saw one day (when i didn't need wires) at ebay some blue custom made wires near 60 USD but i can't remember a thing. The problem with Jenny is that most of the time that i start her up, from 1000 to 2000 rpm she loses one cylinder. I cleaned the injectors, i saw some difference, but it continues to lose a cylinder. One week before i drove 5 Km with 3 cylinders. Big problem. Thats why i am looking for a reliable solution. One more question. Do any of you ever changed the ignition coil? Thanx again fellas.
Old 03 Aug 2012, 03:02 pm
SpannerHound's Avatar
Smile Re: About ignition leads
Are you certain it is a lead problem? Have you cleaned up or replaced the plugs and swapped the leads around to confirm?
An old codger's trick is to use a spray mist bottle with a little water in it, wait till it's dark and spray a fine mist over the leads, if any are leaking and you'll either see the corona discharge, or at least make the engine miss
BTW you can get PowerTec ones from the UK for 22 Euros plus shipping, and a few other brands at waay less money than the OEM ones you are looking at. Better Quality too
As an experienced mechanic and an electronics engineer to trade, I can tell you that coils either work, or they don't and when they don't, it's usually pretty obvious
Old 03 Aug 2012, 03:25 pm
Well where were you when I was posting facts about coils? (transformers)
Old 03 Aug 2012, 03:32 pm
In Scotland where I belong
I don't remember reading your post, where is it?
Old 03 Aug 2012, 03:46 pm
Magnecor are good wires
Tags
ignition wires
Fried PCM/ECU? SKIM? Need some leads jdpersico General PT Cruiser Discussions 19 09 Jul 2012 03:23 pm
Sparkplugs and leads done. Khmer75 General PT Cruiser Discussions 3 11 Jun 2012 02:14 am
can anyone give me leads :( Johns03PT General PT Cruiser Discussions 10 07 Mar 2012 07:53 pm
Recommended new plug leads Boulty Tech & Performance Forum 8 11 Dec 2010 03:11 am
A little searching leads me to a question. spike General PT Cruiser Discussions 6 24 Sep 2010 01:10 pm
