Correct power steering fluid
Old 02 Aug 2012, 02:51 pm
Default Correct power steering fluid
I just want to know what kind of power steering fluid shoukd I use in my 03 PT non turbo?
Old 02 Aug 2012, 03:01 pm
Default Re: Correct power steering fluid
According to an older thread on the subject, anything but the 2001 model uses ATF+4 trans fluid.
Old 02 Aug 2012, 06:43 pm
mdfrodolives's Avatar
Crewzin is correct. I have a 2003 Limited N/A and I put AFT+4 in it (although I actually didn't add to the reservoir. I sophoned out the old fluid and changed it to the new--just because it's been in there since 2003.)
Tim
Old 02 Aug 2012, 06:49 pm
...and even though I have a 2001, my power steering pump went bad in 2003 and when it was replaced, ATF+4 was used to refill. Like you Tim, I just last month siphoned as much as I could from the system and refilled with new ATF+4.
Power Steering Fluid Smell lilfoot General PT Cruiser Discussions 1 11 Mar 2011 12:41 am
Power Steering Fluid ptal Tech & Performance Forum 4 05 Mar 2010 09:40 pm
Power Steering Fluid jmack General PT Cruiser Discussions 12 25 Dec 2008 11:55 am
Gasoline and Power Steering Fluid DIYPTGUY General PT Cruiser Discussions 11 29 Nov 2008 01:47 am
TSB on Power Steering fluid? PTGT Redman Tech & Performance Forum 10 31 Mar 2004 06:42 pm
