A/C problem
Old 02 Aug 2012, 03:25 pm
Default A/C problem
I am having trouble with my A/C on my 2001 PT. When I first turn it on, it works fine. It is nice and cold, and when the fan is up to the highest spot it blows air great. I usually run it on the first or second setting. However, after driving for an hour or two the air flow diminishes greatly. I can have it set on the highest setting and I get almost no air flow and a noisy whirring noise !!! If I put it on the lowest setting there is almost no air flow at all. On high it's like the low setting but lower. If the car sits for a few hours and I turrn it on again, the A/C works fine. Can anyone please help me ?????
Old 02 Aug 2012, 04:15 pm
JenneK's Avatar
Default Re: A/C problem
First guess, bad fan motor.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 02 Aug 2012, 04:40 pm
Sounds like the recycling/low pressure valve to me. It's on top of the accumulator and it's pretty easy to change out for a new one. No loss in R134a. If it's not working, the compressor never turns off and things freeze up and blocks the flow of cold air into the interior. When it's left alone, everything unfreezes and it starts blowing full amount of cold air again. You can also throw on the heater to thaw things out but it's kinda hard to do when it's so hot outside.
Happen to me twice because when you put the new valve on you have to watch out for the tiny "O" ring on the threads of the valve. It squashes and breaks really easy.
Old 02 Aug 2012, 11:28 pm
JenneK's Avatar
Oh yeah! Yeah...that was my second guess!
is it a balljoint problem or a wheel bearing problem? phtech Tech & Performance Forum 2 05 Mar 2011 04:33 pm
Key fob problem ! c13ckb Tech & Performance Forum 0 27 May 2010 10:34 am
anyone ever had this problem Vengence General PT Cruiser Discussions 1 12 Aug 2009 08:58 pm
Help with WGA Problem? Nam9482 Turbo Performance 5 09 Oct 2005 12:57 am
Top Problem cruiserboy PT Cruiser Convertible Forum 0 04 Oct 2005 01:03 am
