Oil Filter - Turbo vs. NA
Old 02 Aug 2012, 04:15 pm
Default Oil Filter - Turbo vs. NA
Hi All,
Just finished an oil change on my NA PT at a friends shop... As it turns out he had just done an oil change on a Turbo PT and commented that although the filter was longer, it looked about the right diameter. So, we fished out the old turbo filter and spun it on mine. Voila, it seemed to work perfectly... but put the new NA Purolator filter on.
So, with the increase in volume of a turbo filter (for both increase in oil capacity and filtering) I'm pretty convinced it makes sense to use it over the NA version... has anyone done this? Any problems or issues? Am I crazy???
Thanks!
BDG
Old 02 Aug 2012, 04:53 pm
Default Re: Oil Filter - Turbo vs. NA
Your not crazy. I use a truck (longer filter) on my Corvette to give it half a quart more capacity but I really don't think you need it with the N/A PT Cruiser engine. We're not talking high performance here.
Old 02 Aug 2012, 07:10 pm
UptownSport's Avatar
Be very careful that the rolled lip doesn't hit something before seal fully compresses;
my bros put a Ford filter on their buddy's tercel (IIRC). It worked fine for many changes, then seal leaked as canister hit block B4 seal could fully compress= ruined tercel engine
Old 03 Aug 2012, 10:15 am
2step's Avatar
......so longer is not always better?
That's good to know.
Old 03 Aug 2012, 11:51 am
Vlefaive's Avatar
That's what I've always been told, but I think they're just being polite.
'03 GT Blue/ autostick.. 160,000KM ( That's 100,000miles for y'all South of the border ) All the options, the heated leather is a must up here in Canada, Love the solid heavy duty feel and obvious Torque.. The Turbo is strong, fast and reliable.. People that don't understand the love of a PT, probably don't deserve to.
Old 03 Aug 2012, 12:32 pm
All About Oil Filters
The longer or larger the filter with regards to extra oil capacity has little effect on the engine. It is the pan that you get the benefits of extra oil capacity. The exception would be if you are running a large oil cooler with remote filter housing and lines.
Using a larger filter then required simply means that if you are operating your engine in an environment that the crankcase would see a lot of dirt the filter would simple have a larger holding capacity to filter and hold that dirt or contaminates within the filtering limits of the brand oil filter chosen.
You need to look into the specification of the exact filter by product # you are using to know if you are gaining anything by its use.
When the filter has reached its capacity to filter the pressure increases and the bypass will divert the flow of oil directly back through the engine unfiltered.
Unless anyone on these boards off roads their PT or travels in an area with dust storms for long periods of time converting to larger capacity oil filter then required serves no real advantage?
Information @
WIX Filters, Wix oil filters, WIX air filters, Wix Heavy Duty Oil filters - Home
FRAM Oil Filters and Air Filters - Choose your region | FRAMŽ
Purolator Auto Oil & Air Filters
K&N High Performance Air Filters, Air Intakes, & Oil Filters
So 2step is correct,.... quote:"so longer is not always better?"
Turbo reacting to K&N filter Joseph Tech & Performance Forum 12 30 Sep 2008 08:42 am
K&N Filter for Turbo turboal Classifieds: For Sale/Trade 1 10 Sep 2007 10:25 am
K & N drop in filter for 01-04 non turbo mjb457 Classifieds: For Sale/Trade 0 19 Jul 2007 07:58 pm
Best Air Filter assembly for Turbo? nozzano22 Turbo Performance 6 30 Jun 2004 04:58 pm
Mobil-1 Oil Filter for Turbo zzzhuh Turbo Performance 7 20 Apr 2003 01:23 am
