A/C High Pressure Switch Installation
Old 03 Aug 2012, 10:08 am
Default A/C High Pressure Switch Installation
I have a 2003 PT Cruiser, standard 2.4 engine. My a/c will not work correctly. The compressor would not come on at all. I replaced the low pressure switch, and the compressor will now kick on for a few seconds, then turn off for a few seconds, then back on, etc. My next step is to replace the high side pressure switch on the compressor. My question is, do I need to depressurize the system before removing the old switch?
Thanks in advance for any information...
Old 03 Aug 2012, 10:31 am
Default Re: A/C High Pressure Switch Installation
Yes, unlike the low pressure (recycling) switch, the high pressure switch lets out the R134a when you replace it.
Before you do that, have you checked the pressure in the system. One sure way of telling if your low, the compressor turns on and off rapidly (every few seconds) and that sounds like what's happening to yours.
Old 03 Aug 2012, 10:36 am
Thanks for the reply! Wouldn't want to get a face full of freon :-)
I've checked the pressure. When I first start the a/c, it show around 240 psi, then climbs rapidly to over 450 psi, when the compressor shuts off. Then it drops back down to the 200s, compressor kicks back on, back to 400s, rinse, repeat.
Old 03 Aug 2012, 01:06 pm
I wouldn't think that would be a fault of the pressure switch. Sounds like it's doing it's job perfectly and telling the compressor to shut down when the pressure is too high.
I'd look into finding out why the pressure is building so fast. Could be it's getting overheated (fan not working properly) or there's a blockage in the system.
A/C Low Pressure Switch, where is it? KJEandLWE Tech & Performance Forum 37 21 May 2017 11:57 am
AC High pressure switch change question Cajunsim Tech & Performance Forum 1 08 Mar 2012 05:43 pm
AC pump high pressure switch joereott21 Tech & Performance Forum 3 07 Oct 2011 08:19 am
A/C High Pressure cut-out Switch myanez Tech & Performance Forum 2 03 Oct 2011 09:59 pm
High Side Pressure switch smithcruiser General PT Cruiser Discussions 4 08 Aug 2009 08:24 am
