Intermittent misfire which seems to get cleared by fault chimes!
Old 03 Aug 2012, 12:40 pm
Default Intermittent misfire which seems to get cleared by fault chimes!
Hi guys, I'm new to the forum and to owning a PT. I have a 2002 2.0 Limited automatic with 36,000 miles. My problem is as follows: I start the car and drive a short distance and it feels like it drops between 2 or 3 cylinders. A 'chime' sounds (which I assume is related to the fault) and this seems to clear the problem and the car runs fine again for the rest of the trip - until you turn off the engine - and then the fault starts up again as described above. No faults are logged on the 'key check' codes - it shows 'done' - so assume all is clear. It had new plugs a short while ago, new intake manifold seals, new air filter, it was serviced at 30,000. Any help gladly received!
Old 03 Aug 2012, 02:39 pm
SpannerHound's Avatar
Smile Re: Intermittent misfire which seems to get cleared by fault chimes!
I guess it could be plug leads, or perhaps one of them wasn't pushed fully home after the plug change
Old 06 Aug 2012, 04:17 am
Default Re: Intermittent misfire which seems to get cleared by fault chimes!
Follow this my friend. It might help you. I think we have the same problem. About ignition leads
P0304 Cleared... duffner Turbo Performance 10 04 Feb 2014 11:26 pm
The chimes whiteclaw General PT Cruiser Discussions 8 05 May 2012 08:29 pm
Stuck in limp mode. Cleared some codes, but... SRT8guy General PT Cruiser Discussions 2 30 Jul 2010 07:15 am
0340 cleared now 0344? tempest0mouthy Tech & Performance Forum 20 10 Nov 2009 07:04 pm
Intermittent Radio RLS7201 General PT Cruiser Discussions 6 21 Oct 2009 05:25 am
