2006non turbo p t A/C problem!!
Old 04 Aug 2012, 03:37 pm
Question 2006non turbo p t A/C problem!!
Please help!! I have had PCM CHANGED previously and new fan is on as well as thermo recently a/c quit working and car would die when idling with a c on, now blows hot air only, had mechanic check it out and he says all switches are good and clutch is good as well as fan so may be PCM AGAIN SINCE no power is going to clutch or fan! Need some advice before buying more parts!
Old 04 Aug 2012, 04:00 pm
Ray_Dockrey's Avatar
Default Re: 2006non turbo p t A/C problem!!
Could be an array of things. Did he check the low and high pressure switches? I would think it would be more of an issue with the TPMI if everything else checks put.
Old 05 Aug 2012, 07:41 am
Yes switches r good, what is the Tpmi?
Old 05 Aug 2012, 08:22 am
It stands for the Total Power Integrated Module. It controls the entire electrical system and also monitors it. If it detects an issue or thinks there is an issue it will shut down the circuit. Once the issue is corrected it is supposed to reset. Problem is they dont. They were problematic on the 2006's because it was the first year they switched to it. You may have to take it to a dealer and have it reflashed. Some cases they have to be replaced which is very expensive. I would verify all wiring and relays are good before committing to taking it to the dealer.
Old 05 Aug 2012, 09:51 am
767skyking's Avatar
Ray Is correct on this. The TIPM go bad on the 06's and it is an expensives to replace. As Ray says, try a reset first
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Is this a turbo problem? Evelyn1342 General Turbo Discussions 3 29 Oct 2011 11:17 pm
PT Turbo problem mtaylor783 General Turbo Discussions 6 03 Dec 2010 08:11 pm
Problem or just turbo? PT_or_not_PT Turbo Performance 0 26 Apr 2010 12:44 pm
Please help with turbo problem hifiman General Turbo Discussions 4 16 Jun 2005 02:43 pm
