engine trouble, no error code
Old 05 Aug 2012, 12:51 pm
Default engine trouble, no error code
I'm sorry if this has already been asked and answered, but I wasn't able to find it by searching old posts. I'm having some engine trouble and I tried to get an error code by doing the on/off/on/off/on trick, and nothing showed up, not even "done". Is there any other way to find out what's wrong without taking it to a shop?
Thanks!
Old 05 Aug 2012, 01:14 pm
767skyking's Avatar
Default Re: engine trouble, no error code
What problems are you having?
The "Three Amigos" (And Growing)
Performace, Body and Service, OEM
"Team Amigos FREE Parts!! PM me for details!!
Old 05 Aug 2012, 02:01 pm
JenneK's Avatar
The check engine light will only come on if the engine is malfunctioning in a way that it would affect emissions. It will not turn on for every performance issue.
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 05 Aug 2012, 02:02 pm
The car initially turned on and when I pressed the gas pedal it moved but in a very jumpy way; the second time the same thing happened and the engine shut itself off after a few seconds. The check engine light turns on and flashes 10 times before staying on.
Old 05 Aug 2012, 02:04 pm
JenneK's Avatar
Tell us about the car. Details!
Any engine work recently performed?
When did this problem present itself?
Old 05 Aug 2012, 02:33 pm
Also, what's the status of the ignition system (plugs and wires). Here's a post where an owner had the same symptoms and new plugs and wires solved the problem.
Check Engine Light Flashing on acceleration
Old 05 Aug 2012, 02:47 pm
It's an '04 Turbo. After about 15 seconds if I press the gas at all the engine shuts itself off but it's ok before then. Recently had the starter replaced but that's the only work that's been done lately. Showing my absolute ignorance here but how would I go about checking the ignition system?
Old 05 Aug 2012, 03:25 pm
JenneK's Avatar
Originally Posted by apsenniel View Post
It's an '04 Turbo.
Whoa right on, thanks for all the details man!
Sounds like a fuel pump to me.
So it idles but will not accept any gas under load? Can you rev it in Park?
Check engine light:
` Turn key to ON (but do not start) 3 times within 15 seconds.
` On the last time keep in ON position (not started).
` Look at odometer and record the codes. They should start with "P" followed by 4 numbers.
Old 05 Aug 2012, 03:56 pm
I've tried to get an error code that way several times and nothing happens. Update: engine no longer starting at all.
Old 05 Aug 2012, 07:32 pm
SpannerHound's Avatar
Smile Re: engine trouble, no error code
Back to basics then, check for fuel delivery and a spark...go from there
Error Code P0303/Check Engine Light ohiomas Tech & Performance Forum 1 10 Apr 2011 02:47 pm
Engine Light ON - no error code PeeTeeCruizer Tech & Performance Forum 2 23 Oct 2010 02:32 pm
Engine light P2097 error code help jbh1860 Tech & Performance Forum 2 20 May 2009 12:30 pm
Error code trouble P0132, 1686, 1687, 1681 SolidusGorto General PT Cruiser Discussions 0 19 Jun 2008 07:59 am
P0325 Engine Error Code on 2003 PT Turbo intim3 General Turbo Discussions 0 12 Aug 2007 08:06 pm
