help needed
Like Tree2Likes
Old 08 Aug 2012, 01:06 pm
crazyptguy's Avatar
Default help needed
my hood is stuck shut thought it was the cable and im waiting on a new latch but its not but my problem is i have to work on my dash today and need to know if i pull the airbag fuse will they go off when i replace it? what if any fuses should i pull to replace dash lights? radio thanks guys
03 Pt Woody Classic 116k miles Rebuild project.
Old 08 Aug 2012, 01:36 pm
SpannerHound's Avatar
Smile Re: help needed
I'm not sure I understand your question correctly, but if you are asking "will my air bags fire because I removed the fuse and refitted it" then the answer is no, they won't fire. Pulling the fuse is no different to removing the battery
I would find a way to manually open the bonnet(hood) and disconnect the battery, that way there's absolutely no chance of accidentally shorting something during strip down/ rebuild. If you were to be unlucky you could damage the PCM or an associated module. It's not worth the risk in my opinion
Old 08 Aug 2012, 02:17 pm
Default Re: help needed
Go to the "tech & performance" section and then to the sticky "how to" section and then to my directions on "how to open hood when cable breaks". Everyone that has followed my directions has been able to open the hood so far.
There are two fuses in the interior fuse box that are air bag related, numbers 5 and 10 if I remember correctly. Personally, I would open the hood and then remove negative battery cable and then step on the brake pedal for a couple minutes if I were doing this.
Jerry
Jerry
Old 08 Aug 2012, 07:07 pm
mdfrodolives's Avatar
Do what Jerry says.
Tim
wwpptc likes this.
Old 08 Aug 2012, 07:53 pm
Originally Posted by mdfrodolives View Post
Do what Jerry says.
Tim
Always!
wwpptc likes this.
Old 08 Aug 2012, 09:45 pm
crazyptguy's Avatar
thanks guys i got the hood open the hood latch hook twisted and was stuck around the catch on the hood no screwdriver would open it i took a couple of reaally long extensions and a ratchet and unbolted the latch from the support. now on to replace a rke module,and dash lights while im there. oh jerry why the brake pedal? never heard of that
Old 08 Aug 2012, 10:30 pm
Mainly it's just a habit I've gotten into anytime I work on our PCM controlled cars. It's especially important for instance, when you're working on your airbags and trying to remove any remaining stored residual power anywhere in your electrical system that might set the bags off and make you walk in circles while singing "Its a small world" for the remaining productive years of your life.
In other words, anytime I feel the need to unhook my battery to do something, I always "drain the system".
Jerry
Old 08 Aug 2012, 11:42 pm
crazyptguy's Avatar
should i be worried i have been singing that since i bought the pt LOL
Old 09 Aug 2012, 09:17 am
Yes, yes you should!
Jerry
Old 09 Aug 2012, 09:46 am
Ray_Dockrey's Avatar
Don't have a big fear with dealing with the airbag. Just be cautious and it will be fine. I had to remove mine on my 2009 and was terrified. But as suggested I unhooked the negative, pressed the brake pedal several times, and then let it sit for about 15 minutes. Didn't have any issues at all.
Some Help Needed Please!! LJ13 Tech & Performance Forum 3 02 Nov 2010 06:22 am
Help Needed Rich Wheels, Tires, Suspension 7 20 Jul 2009 06:06 pm
air box lid needed gmrviper Classifieds: For Sale/Trade 4 17 May 2008 06:12 am
Help needed? bluwoody PT Cruiser Convertible Forum 0 15 Dec 2004 04:08 pm
needed skeeter1620 Exterior Accessories Forum 7 31 Dec 2003 12:01 am
