Battery Drain Question
Like Tree2Likes
Old 09 Aug 2012, 10:37 am
Default Battery Drain Question
Hey everyone: new to the forum and to the Cruiser. I have searched the forum for information regarding a battery drain on my car. I have only had it for six months an replaced the battery twice. According to mechanic alt/starter are fine and I must have a parasitic drain.
I read on here about the fog light issue, however my cruiser doesnt have fog lights? But there is a fuse for foglights in #8 is this normal?
Kinda an amateur mechanic here and would appreciate all info / help.
Old 09 Aug 2012, 10:53 am
Default Re: Battery Drain Question
Since you say you don't have fog lights, the first thing I would do is remove the #8 fuse, just for giggles. If your mechanic is at all worth his title "mechanic", he can (and should have) easily check for a draw on your battery. You may have a multi-function switch problem, but your mechanic should be able to narrow that down for you.
Jerry
Ray_Dockrey's Avatar
Can you tell us a little more about the car? What year, mileage and stuff like that?
Old 09 Aug 2012, 11:43 am
Sure it's 2001 non turbo, purchased from major dealer, only 1 owner and it appears most maintenance has been up to date. At least according to the logs the previous owner left in the manual. It has 150,000 miles - appears to be all OEM except for a sony in-dash cd player. The mechanic actually referred me to someone who specializes in battery parasitic drains? I purchased a battery bypass switch and thats what I am using thus far. I did notice that the air conditioning compressor went out about around the same time the battery drain was noticeable but I had been driving the car daily then. If I do not drive daily but every other day the battery is almost 100% dead after about a week.
Thanks again guys
Old 09 Aug 2012, 12:10 pm
And you are sure he checked the alternator?
Old 09 Aug 2012, 12:34 pm
Not positive but I was told the alternator and starter were checked. Does this sound more like an alternator issue to you? I thought that if there were alternator problems it would die while driving etc? Correct me if im wrong, but it seems to be driving fine once started.
Old 09 Aug 2012, 12:58 pm
What did the "parasitic drain specialist" find?
Jerry
Old 09 Aug 2012, 01:12 pm
I havent taken the car to them yet, was trying to avoid it, but it's looking like it might be my only option. I thought about removing the fuse to the aftermarket cd player just to check.
Old 09 Aug 2012, 01:40 pm
I see.
Jerry
Old 09 Aug 2012, 02:46 pm
cruserdad1976's Avatar
some cars can drain back throught the alrenator my old 75 chevy truch does this if i dont unhook the battery
A why & a How question about battery blucruzer General PT Cruiser Discussions 29 16 Sep 2010 06:19 pm
Battery Drain ??? Derrick Tech & Performance Forum 18 28 Feb 2010 07:44 pm
Battery Replacement Question bados Tech & Performance Forum 8 15 Nov 2007 03:37 pm
Do lights/lighter drain battery to death? zzzhuh General PT Cruiser Discussions 11 04 Mar 2004 08:11 am
