A/C Problem after replacing compressor and dryer
Old 09 Aug 2012, 04:34 pm
Default A/C Problem after replacing compressor and dryer
Have A 01 that I have just replaced the A/C compressor and the dryer. Got it all installed and pulled a vaccum. Started charging the system all was good getting cold air.Pulled it out of the garage to test drive and it started blowing hot air again. I only have a gauge for the low side and it was OK. Swapped out the a/c relay with the horn relay not a relay. Both fuses OK. I sure could use some help with this one.
Old 09 Aug 2012, 05:01 pm
JenneK's Avatar
Default Re: A/C Problem after replacing compressor and dryer
Is the radiator fan running when the AC is on?
Ken posting about his Jenny's car.
01 w/JBA headers, Borla catback, Airaid intake, lowered, purple with shiny wheels.
Old 09 Aug 2012, 07:16 pm
Is the compressor running?
Old 09 Aug 2012, 07:51 pm
After reading about the fan issue I went out and started my PT and let it idle till the Temp. gauge was in the middle between cold and hot. The fan never kicked on at all. I guess I need to check the fan issue. Not sure how to check this, could some one give me some instruction please.
Old 09 Aug 2012, 07:52 pm
Also the compressor has not kicked on since I charged it. Both lines are very hot!
Old 09 Aug 2012, 08:46 pm
Sorry to keep adding things but I have got the fan motor unplugged and use the 12 volt battery to test. The plug has 3 prongs. I hooked up the hot to a outside prong and the neg to the middle one the fan came on. I can't get it to come on with the other outside prong. Is the fan motor shot?
Old 09 Aug 2012, 09:06 pm
Went over to alldata and got the wiring diagram. From what I have read there and testing the fan motor my high side will not start the fan. Is this my trouble? a new fan motor?
Old 09 Aug 2012, 09:17 pm
Ray_Dockrey's Avatar
sure sounds like it especially since they are a common point of failure. But normally once you get driving down the road the air will get cold.
Old 09 Aug 2012, 10:36 pm
mdfrodolives's Avatar
If you tested the other side of the fan plug--and the motor didn't turn on--you need a new fan. RockAuto has a Dorman (a good one) for a good price.
Tim
Old 11 Aug 2012, 03:36 pm
OK guys, I am still having trouble! I have replaced the fan motor last night and recharged my a/c system. Drove it around town for a few minutes and all was good. Drove it on the highway this morning and it quit blowing cold. Got home awhile ago. Thought I might have a leak in the system. Checked the low side pressure and it was off the charts high. Both lines are extremely hot as well. Need help.
Ac compressor Jimmyo Tech & Performance Forum 12 23 May 2012 04:27 am
A/C Compressor Oil RaceWilson General PT Cruiser Discussions 0 28 Apr 2012 05:30 pm
a/c compressor fattmann Tech & Performance Forum 1 20 Mar 2012 10:24 am
A/C Compressor problem kfellers Tech & Performance Forum 2 04 Apr 2009 11:46 am
AC compressor rickmancc Classifieds: Want To Buy 0 10 Jun 2008 10:55 am
