Thanks for error code help
  • 1 Post By mycar
Old 10 Aug 2012, 01:31 pm
Default Thanks for error code help
Would have been in a jam if not for the help here. Was able to retrieve error code by three little clicks of key (after spending $100 on code reader) then was able to locate the faulty part by breakdown of codes and location and instructions of how to change that part. That $35 Power Steering Pressure Switch would probably have cost me hundreds to have diagnosed and repaired by shop. Thanks guys!
Busted_PT likes this.
Old 10 Aug 2012, 02:47 pm
Default Re: Thanks for error code help
The forum thanks you. Now go wash up because I know that Power Steering Pressure switch is a messy job.
Old 10 Aug 2012, 10:57 pm
I cleaned up OK but my brake fluid soaked shirt has seen better days. Hey Cruewzin, what's up with the badge...looks a lot like the one I wore back in the 70's as an Arizona, Maricopa County Deputy Sheriff...The Good Old Days.
Old 11 Aug 2012, 07:25 am
Click on my User Name, View Public profile.
Error Code 320 okla2001pt Tech & Performance Forum 1 17 May 2010 12:42 pm
error code... superpug666 Tech & Performance Forum 16 13 Oct 2009 07:33 pm
Error code 601 COOLSILVER02NV Tech & Performance Forum 7 14 Jul 2009 10:52 am
Error Code saldagus Tech & Performance Forum 2 25 Nov 2008 09:51 pm
Error code??? russ00001 Tech & Performance Forum 0 29 May 2007 04:24 pm
