Groaning sound after complete stop
Old 11 Aug 2012, 10:43 am
Default Groaning sound after complete stop
My 08 PT Cruiser has started making a groaning type sound after I come to a complete stop. Doesn't make the sound while braking, only after car is stopped. Also makes the sound when start going again after stop. These are the only times I hear the noise. Any ideas what this might be?
Old 11 Aug 2012, 11:28 am
SpannerHound's Avatar
Smile Re: Groaning sound after complete stop
You might need to expand on that fault description a little...
The groaning could be a few things from brakes to suspension to belt/ pulley noise to power steering pump noise to just about anything!
Try to pinpoint where on the car the noise is emanating from, front, back, which side etc. Try turning the steering wheel from side to side when stopped and see if the noise gets louder or quieter. Is the noise only there going round a left hand corner or a right hand one etc. You get the idea
Old 11 Aug 2012, 09:08 pm
Default Re: Groaning sound after complete stop
Thanks for the reply, Spannerhound! It's not a continuous groan, just happens right after I have complete a stop. I press the brakes, the car stops, I hear the groan sound once. Happens every time I complete a stop, but not while I am braking. Sometimes I hear it once when I start going again, just one groan. I say groan because it's not a grinding sound, more like a groan. Doesn't happen when I turn the wheel or any other time. Doesn't happen when I go over the speed bumps in my apt complex. Definitely coming from the front of the car. I am familiar with brake noises. The front brake pads and rotors are only about 6 months old. This noise just started within the past 2 months. Have been driving for 38 years and can't say I've ever heard this particular noise with any of my other cars. Was hoping someone else might have had this problem and could tell me what it is.
Old 11 Aug 2012, 09:15 pm
Check your control arm bushings, behind the front tire. The sway bar bushings. Also check the upper and lower motor mounts.
Old 11 Aug 2012, 10:40 pm
Talking Re: Groaning sound after complete stop
Could it be the torque converter/lock up clutch?
Old 11 Aug 2012, 10:47 pm
Nope, be willing to bet it's either a bearing or brakes/rotors. Sometimes you have to pull your rotors and jet wash the wheel cylinders to allow the pistons on the breaks to free up easily. Sometimes it's rear breaks, when you adjust your breaks to reduce the amount of play in the pedal, sometimes the rears will drag a bit as you pull away. Also, sometimes you need to just take the wheel off and uncover the rears so that you can jet wash them. They tend to get tons of buildup of crud and that can cause the groaning sounds.
Me, I'm constantly cleaning my wheels and brakes because I'm probably OCD and want my car to always look brand new, so I don't ever have brake groaning. However, I live right next to a lake and every morning we get enough dew to make it look like it rained, and the first time I back out of the driveway my brakes squeal a bit - yes the factory rotors tend to get a dusting of rust overnight from all the moisture in the air. The squeal lasts only a few seconds, usually two taps on the brakes while moving and it's gone.
Old 11 Aug 2012, 11:00 pm
Exclamation Re: Groaning sound after complete stop
I am OCD, and I understand the apparent humor of it.
If you were truly ocd, you would know it, and be on meds daily for it and see a shrink and a psychotherapist for cbt for which I do.
Big difference between being a fanatic about something and ocd
Old 11 Aug 2012, 11:04 pm
See, now you're not OCD.... if you were, you'd be spelling OCD in caps...hahahahaha... my wife calls me OCD, and also calls me Mr. Safety Man. I won't move my car if I have passengers aboard and someone has not put on their seatbelt. I never leave my dock in my boat with passengers until they all shut up and listen to my safety speech, where the fire extinguishers are, floatation devices, flare gun, emergency whistle and horn, etc.
So, I guess I could be called Mr. OCD Safety Man...lmao...
Old 12 Aug 2012, 12:31 am
It's either brakes or strut tops I reckon
Old 12 Aug 2012, 07:53 am
Sounds like a mixed bag of Planters nuts, arguing about who is nuttier!
Tags
complete stop, groaning noise
Recommend me a complete sound system Nameless Sound and Security Forum 5 18 Oct 2011 08:10 am
very odd sound from a stop superj Tech & Performance Forum 0 21 Feb 2011 09:53 am
groaning ? lunyty Wheels, Tires, Suspension 1 10 Feb 2011 11:50 am
Complete Replacement of Sound System. Ideas? ecarfar Sound and Security Forum 5 28 Jun 2004 06:26 pm
