tranny swap suggestions?
Old 12 Aug 2012, 02:29 am
Default tranny swap suggestions?
Hey guys,
I'm new to the forum and just starting to get some mods on my 2006 pt turbo gt...One mod I am desperate for is possibly converting to a manual transmission but I am striking out in finding anything for a 2006. would any of you have any recommendations on compatible swaps i can look into for this? any help would be greatly appreciated!
Old 12 Aug 2012, 04:22 am
Kawizx9r's Avatar
Default Re: tranny swap suggestions?
My honest suggestion would be to buy a manual PT GT.
Look for an 03 with minimal options; less options means less weight so better platform to begin with.
The auto is a 41TE, the manual is a 5-speed Getrag in case you were interested.
Kawi is a friggin genius!
Old 12 Aug 2012, 10:58 am
SpannerHound's Avatar
Smile Re: tranny swap suggestions?
I would be looking for a cheap base model with manual transmission as a project platform, if I were crazy enough
Old 12 Aug 2012, 02:32 pm
UptownSport's Avatar
Non-turbo had T-350HD, a strengthened Neon/stratus transmission.
Turbo Neon had the t-850
As Kawi said, PT Turbo has a getrag.
All will bolt to the 2.0/2.4.
Obviously, non-turbo axles will work with T-350.
You can use old Neon/Stratus T-350 in the PT by swapping the bellhousings, or just grab one out of a '01 up Neon.
Turbos had a jackshaft so axle halves would be equal length.
I *THINK* guys did this on t-350's, but you'd have to research.
The old T-350 has held up to TREMENDOUS power (with slicks!) in the PL body-
however things change drastically when you add chassis weight.
Old 12 Aug 2012, 07:49 pm
xwing777's Avatar
I was in the same boat. Wanting to change over to a manual so i could continue the HP quest. Not having a lot of luck finding all the parts required to do it correctly at reasonable cost (wasnt going to splice/cut wires, wanted key switch to work correctly, no errors in PCM,etc...)
I lucked up and was in the right place at the right time and picked up the 03' GT 5-speed for about the cost just for parts to convert mine.
It may take a while but wait till you can find a manual turbo. Its a headache and a chunk of money to convert one correctly.
Old 12 Aug 2012, 10:16 pm
Here's a reference to equal length axles retro for the Neon-
It's speaks about bosses on block, something which a late Model PT would already have.
Equal-Length Upgrade - Which blocks does it fit?
Interesting, this is why they moved the crank sensor from early PT's to later PT's!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Tags
pt turbo, swap, tranny
tranny swap? theKING General PT Cruiser Discussions 14 02 Dec 2013 02:13 am
Need suggestions eaduby General PT Cruiser Discussions 8 25 May 2012 06:22 am
Tranny swap bhunt41 Tech & Performance Forum 21 11 Aug 2011 09:18 pm
tranny swap buttersandpaper General Turbo Discussions 6 15 Sep 2006 03:49 pm
tranny swap VellianPT Tech & Performance Forum 4 02 May 2005 08:45 am
