abs trac off probs
Old 12 Aug 2012, 07:39 am
Default abs trac off probs
Hi all i have a 2002 and the trac off,abs lights are on all the time . the trac light has started to come on when i pull off and judders a bit for about 5 seconds anyone any ideas thanx Tim (happy cruiser)
Old 12 Aug 2012, 10:32 am
SpannerHound's Avatar
Smile Re: abs trac off probs
I would suggest perhaps an ABS wheel sensor or the wiring to em. I'm sure one of the others will have a better idea
Old 12 Aug 2012, 02:15 pm
Default Re: abs trac off probs
thanxs spannerhound will try it
Old 14 Aug 2012, 09:49 am
I agree on the wheel speed sensors. I had an ABS light on my 2010 when one of my sensors failed.
-Chris
Old 14 Aug 2012, 02:43 pm
thanx Chris
Old 14 Aug 2012, 03:41 pm
Also check the ground wires from the body to the hubs. Should be a braided ground cable connecting between. If not, then you can build up enough static to throw off the sensors. I've seen plenty of PT's where some idiot mechanic cut the leads, thinking they were smarter than the design engineers. Not a good idea, rotating metal around metal causes static, and you can guess how much that might affect your PT, so I suggest checking those ground leads.
MBC location and ECU probs PETEY_CRUISER Turbo Performance 10 24 Oct 2015 08:45 pm
Stalling probs jimbo1 General PT Cruiser Discussions 3 14 Jun 2011 12:14 am
Electrical Probs R_I_PT Tech & Performance Forum 2 04 Jan 2009 08:36 pm
Air conditioner probs. ccinder General PT Cruiser Discussions 2 18 Jun 2008 09:35 pm
MBC Probs PETEY_CRUISER Turbo Performance 5 20 Jun 2003 02:12 am
